• Support PF! Buy your school textbooks, materials and every day products Here!
Center of mass of a vehicle
  • Thread starter Altairs
  • #51
127
Ah … now I see …
No, when you said 1/4 th of the car, I thought you meant that only one tyre was on the platform
Oh...right..
  • #52
tiny-tim
25,832
251
The idea is that the whole car will be over the platform. Then the car will be lifted from it back by men or something so that they will be standing on the ground. My point was that there is no difference in this and simply putting front two tyres over and rear two tyres off the platform but my friends wouldn't agree.
If the men are lifting it by holding onto the rear axle, then your friends are wrong, and you are right … the distribution of the forces (or reactions) depends only on the positions of the points of support on the car.
(But if the men are holding it by the tow-bar under the rear bumper, then the reading will change, because the c.o.m. is further from the tow-bar.)
Second point is that will this procedure (the tipping one) when performed for both the front and the rear tyres equal the weight ?
Sorry … I'm not following this at all … why would you get men to tip the car when you can get the same reading by leaving the rear tyres on the ground?
  • #53
when we tilt the car and find the reaction thn v'l hav a frictional force acting on the tyre,in contact with the ground apart from the surface reaction so will we consider it as limiting friction or how do we calculate it?
  • #54
tiny-tim
25,832
251
Welcome to PF!
Hi Whatevr! Welcome to PF! :smile:
The weighing platform will only measure the vertical reaction, and the friction force is entirely horizontal, so the friction force will make no difference. :smile:
  • #55
but when u find the z distance u take moments abt a point nd therefore u hav 2 kno all the forces how else wud u claculate the distances
  • #56
tiny-tim
25,832
251
Hi w'v'r! :smile:
ah, you've made a good point … if the higher pair of tyres is supported on a sloping surface, then the friction will spoil the equations.
So it is important that the higher pair of tyres (or its axle) be supported on a raised horizontal surface. :smile:
  • #57
no i dont get it:( that wont b possible i thnk or the frictional component wud stil exist ??
friction will exist if we raise the car frm one end
  • #58
tiny-tim
25,832
251
If all the wheels are on horizontal surfaces, why would the car want to move anywhere (even with the brakes off)?
There'd be no gravitational advantage in moving. :smile:
  • #59
no but thn how'd we calculate the z distance i.e. the height part?
  • #60
127
If we can do away with the friction part than it is quite simple.
  • #61
ummmmmm thats the prob that friction exists and we hav 2 b as exact as possible so v hav 2 consider friction
  • #62
127
I still don't see any point in taking friction. Secondly, I don't have the wildest idea that how will we calculate friction in our case( I am even confused that while the car is in horizontal position with no external horizontal force acting over the platform the friction is acting or not !!!). Its definitely not limiting. Thirdly, we have to give a 'standard procedure'. With friction involved it won't remain standard as we would need to know the different values of [tex]\mu[/tex] for different contacting surfaces (tyres and platforms).
  • #63
127
This situation can also be simulated by hooking the front end of the car (from bumper or something) and then lifting.
  • #64
tiny-tim
25,832
251
Hi Altairs! :smile:
Yes … provided you ensure that the rope is vertical once the car is raised!
Though there is a practical problem … I don't think there's anything at the front of a car that's strong enough not to be damaged. :cry:
  • #65
127
Something can be attached as an extension to the front side and then the it can be hooked.
  • #66
i dont get how ur trying 2 remove friction........
  • #67
127
How are we supposed to calculate the friction present :confused: ?
  • #68
tiny-tim
25,832
251
By fixing it so that the friction is zero, which means supporting the wheels on horizontal surfaces, or the towbar on a vertical rope. :smile:
  • #69
127
That is exactly what I thought (post 62).
[tex]4F_{s} = 0 [/tex] (fixed and no external forces present horizontally)
  • #70
tiny-tim
25,832
251
Hi Altairs! :smile:
(btw, don't send a Visitor Message if it's important, since there's no notification of Visitor Messages, and I might not see it for days. Send PM if you think I've missed a post.)
Yes … ignore friction …
… your post #62, replying to Whatevr, was completely right (which is why I didn't comment on it).
  • #71
ok so can u tell me how do we calculate the z-distance i.e. the height co-ordinate. we can get both the horizontal distances but wat abt the vertical one??
Related Threads on Center of mass of a vehicle
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
