What is the center of mass of a pyramid?
In summary, Daniel was trying to find the center of mass for a 3-D object, but was unsuccessful. He tried to do the integral, but was confused by the A(y) part of it. Tide tried to simplify things for him, but Daniel was not satisfied.
TraceBusta
35
I know how to find the center of mass of a 2 dimensional object like a piece of plywood or something like that, but when it comes to 3-D objects I'm clueless.
All I know is Mx=x1m1+x2m2+...xnmn
here is my problem, i don't know if i should split the pyramid into 4ths or not.
The Great Pyramid of Cheops at El Gizeh, Egypt, had a height H = 144.9 m before its topmost stone fell. Its base is a square with edge length L = 233 m. Its volume V is equal L2H/3. Assuming that it has uniform density p(rho) = 1.8 x 103 kg/m3.
(a) What is the original height of its center of mass above the base?
(b) What is the work required to lift all the blocks into place from the base level?
Find the center of mass for one face [treating it as a two dimensional triangle]. Project a line through and perpendicular to the center of the face. Find and project a line perpendicular to the center of mass of the base [a square]. Align the base of the triangle with the pyramid base and rotate it to the correct angle. The center of mass is where the two projected lines intersect [don't forget to plot the coordinates in three dimensions - x,y,z].
If B is the area of the base of the pyramid then the area of a cross section y units above the base is
[tex]A(y) = B \left( \frac {h-y}{h} \right)^2[/tex]
where h is the height of the pyramid. You can use this to find both the volume of the pyramid and the center of mass:
[tex]V = \int_0^h A(y) dy = \frac {1}{3} B h[/tex]
and
[tex]\bar y = \frac {\int_0^h y A(y) dy}{V}[/tex]
but I'll leave the second integral for you to do. :smile:
the work?
As to part B of this problem. Would the work be the integral of mgh? where after you integrate it would be mg*h^2/2 ?
The work would be the integral of [itex]\rho g y A(y)[/itex] which should look familiar to you.
Recall for the laminar ones you were describing:
[tex]\overline{x} = \frac{1}{A}\int{x}{f(x)}dx[/tex]
[tex]\overline{y} = \frac{1}{2A}\int{[f(x)]^{2}dx[/tex]
What if you want to find the center of mass of a triangle?
By symmetry, locate the y-coordinate of the center of mass of an equilateral triangle of side length l=95cm located with one vertex on the y-axis and the others at (-l/2,0) and (l/2,0).
does this also involve integrating?
I have a question about this. Wonder if I can bring this thread back.
- harsh
Ok, phew. So, here is my problem when I try to figure out the center of mass of a pyramid. My answer is outside the damn pyramid, which doesn't really make sense at all.
The pyramid has uniform mass density, so rho = M(tot)/ Volume
Volume = 1/3 b h
Now, when I try to integrate, I get my coordinates to be outside the damn pyramid. Any ideas? Where am I going wrong?
- harsh
Well, how did you do this integral then?
Well, okay, so here goes:
Say the base is a square with length s. And I put the pyramid at the origin. My limits, whether they go from 0 to S or -s/2 to s/2, should give me the same result. Anyways
Triple integral, with limits 0->h, 0->s, 0->s, with respect to dx, dy, dz respectively. Then, since rho is constant, (I can take out 3Mtot/s^2*h) out of the triple integral.
Since its also independent of z and y, (for the x coordinate of the center of mass), you can solve those integrals readily. So far, after cancellations and doing the integral, I get 3s/2. Is that correct?
- harsh
What triple integral are you talking about...?Tide has come up with a simple integral.Why didn't u take his advice...?
Daniel.
Daniel.
I am using the generic formula for the center of mass:
x(cm) = Triple integral, with the limits, of ((rho)(x)(dV)) / mass
Same thing with y and z, except inside, you replace with y and z respectively. I actually looked at that, but didnt understand the A(y) part of it.
- harsh
Well,Tide explains what it means.It's the area of the cross-section through the pyramid made at the height "y".
Just make a drawing and convince yourself it is true.
Daniel.
Daniel.
Well, I will try to figure it out myself. Thanks for your help
- harsh
- harsh
First off: Your limits are totally wrong!
You are describing a box, not a pyramid.
Secondly, for your box:
[tex]\hat{x}=\frac{\int_{0}^{h}\int_{0}^{s}\int_{0}^{s}\rho{x}dxdydz}{\rho{h}s^{2}}=\frac{\rho{h}\frac{s^{3}}{2}}{\rho{h}s^{2}}=\frac{s}{2}[/tex]
I have a question. In the denominator, shouldn't it be (rho)*1/3*s^2*h ? Since its rho * volume?
I see what you are saying about my limits, I guess they do describe a box. I think I need to change my x and y limits, maybe some sort of a plane?
- harsh
Since the geometry is really simple, you can change your variables as follows:
Regard the pyramid as the set of all straight lines connecting a point in the (x,y)-plane with the vertex (s/2,s/2,h).
That is, by letting u,v be coordinates of a point in the (x,y)-plane (ranging from 0 to s), while w measures where on a particlar line segment you are (ranging from 0 to 1), you have:
[tex](x,y,z)=((u,v,0)-(\frac{s}{2},\frac{s}{2},h))w+(\frac{s}{2},\frac{s}{2},h),0\leq{u,v}\leq{s},0\leq{w}\leq{1}[/tex]
or:
[tex]x=(u-\frac{s}{2})w+\frac{s}{2}[/tex]
[tex]y=(v-\frac{s}{2})w+\frac{s}{2}[/tex]
[tex]z=h(1-w)[/tex]
Hence, the Jacobian is:
[tex]\frac{\partial(x,y,z)}{\partial(u,v,w)}=w^{2}h[/tex]
I used the volume of a BOX, since a box it was..
or:
[tex]z=h(1-w)[/tex]
I sort of see what you did. You are basically coming up with an equation of line that has intercepts at the summit of the pyramid and the base (being the x-y plane) ? Is that the correct way to think about this?
Damn, I should have thought of coordinate change. Thanks for all your help. Please let me know if the way I am thinking of your coordinate change is okay or not.
- harsh
- harsh
Yeah:
A given (x,y,z)-point within the pyramid can always be thought of lying somewhere along some particular straight line segment joining the vertex and the base. u,v defines the intercept point at the base (and hence, which line segment (x,y,z) lies on), whereas w gives you the precise location of (x,y,z) on that line segment.
The center of mass of a pyramid is a point that represents the average position of all the mass in the pyramid. It is the point at which the pyramid would balance if it were placed on a pivot.
How is the center of mass of a pyramid calculated?
The center of mass of a pyramid is calculated by finding the weighted average of the positions of all the individual mass elements in the pyramid. This is done using the formula:
x = (m1x1 + m2x2 + ... + mnxn) / (m1 + m2 + ... + mn)
y = (m1y1 + m2y2 + ... + mnyn) / (m1 + m2 + ... + mn)
where m is the mass and x and y are the coordinates of each individual mass element.
How does the shape and size of a pyramid affect its center of mass?
The shape and size of a pyramid can greatly affect its center of mass. A taller and narrower pyramid will have a higher center of mass, while a shorter and wider pyramid will have a lower center of mass. The shape of the base can also impact the location of the center of mass. Generally, the center of mass will be closer to the base if the base is larger and wider.
Why is the center of mass important in studying pyramids?
The center of mass is important in studying pyramids because it helps us understand how the pyramid will behave when forces are applied to it. If the center of mass is located closer to the base, the pyramid will be more stable and less likely to tip over. It also helps in designing structures and determining the distribution of weight in the pyramid.
Can the center of mass of a pyramid be outside of the pyramid?
No, the center of mass of a pyramid will always be located within the pyramid itself. This is because the center of mass is a point that represents the average position of all the mass in the pyramid, and all the mass is located within the pyramid.
13K
