How Much Force Must Each Person Exert to Carry the Couch Levelly?
In summary: Yes. The left person's moment of inertia is different from the right person's moment of inertia because the left person is sitting closer to the right person.
mxh91
Two people are carrying a 2 m long couch with a mass of M=20kg level with the horizontal by lifting it from it ends. The center of mass of the couch is 1 m from each end. While it is being carried, another person with a mass m of 60 kg sits on the couch 0.5 m from one end. How much force will each person carrying the couch have to exert upwards in order to continue carrying the couch levelly?
I don't have a clue on how to start this problem. Does anyone know?
Well I know that this is a center of mass problem. I know that Center of mass is equal to sum of each mass times its position all over the total mass of particles.
I've drawn a free body diagram here: http://4.bp.blogspot.com/_-h5patrZ790/TP5DhJfAiNI/AAAAAAAAAV4/xFnT20VqzrI/s1600/Couch+question.PNG
See if it helps u.
Kikora said:
Thanks for the picture! The way I would think about solving this problem is that since no one is sitting on the right side of the couch, the person on the right is lifting the right half of the couch's weight. So that would be 20 kg / 2 = 10 kg. Then you multiply this weight with gravity's acceleration and I got 98 N. So the person on the right would have to put 98 N into lifting that side of the couch up. After that, we can do the similar steps for the left side. Is this logic correct?
Eh. No. Use moments about a point.
Clue: Take moments about the left person.
Note: By the way, In your 3rd sentence, its "multiply this mass with gravity's acceleration" and not "multiply this weight with gravity's acceleration".
So I have to take moments about the left person because the 60 kg person is siting closer to him right? So would it be (60 kg)(0.5 m)/(60 kg + 20 kg) ?
Erm. Actually, after solving for the force exerted by the right person, you'll need to find the force exerted by the left person later as well. The forces exerted by the right and left person are not equal.
No. Use
Taking moments about left person,
Clockwise moments = anti-clockwise moments
No. Use
Hmm, I'm confused about the moments of left person. Would the total force exerted by both right and left person be 784N since the total mass is 80 kg and I multiplied it by 9.8 m/s^2?
You are right. The total force exerted by both right and left person is 784N.
What i meant was force exerted by left person is not equal to force exerted by right person. You will need to take moments about left person to find the force exerted by right person. And hence, find out the force exerted by left person.
Hmmm, the Center of Mass of the couch is at located in the middle of the couch. But since we have external forces acting on the couch, would this center of mass point move? If so, I have to find this new point?
The centre of mass of the couch will not move.(It is still in the middle) However, the centre of mass of the couch and the person sitting on the couch will be between the arrow(weight of the person sitting on couch) and the arrow (weight of couch). You do not have to find the new point.
More clues to help you:
(weight of person sitting on couch)(0.5) + (weight of couch)(1.0) = (force exerted by right person)(2.0)
Ohh! Let me see if I get this right. The reason why we take moments about the left person is because there is an external force (weight of 60 kg person) acting on the left side of couch right? So we set the moments about the left equal the moments about the right (not sure why).
So (60 kg x 0.5 m) + (20 kg x 1.0 m) = (20 kg x 2.0 m) right? But since they are asking for force, we have to multiply both sides by 9.8 m/s^2.
294N m + 196 N m = F (2 m)
F (right person) = 245 N
F (left person) = 784 N - 245 N = 539 N
Right?
Actually, the reason why we take moments about the left person is so that we do not need to take into account of the unknown force exerted by the left person. Hence, we can solve the equation with 1 unknown(force exerted by right person) instead of having two unknowns(if you take moments about the centre of the couch). You can take moments about the right person instead if you wish(hence solving for the force exerted by the left person).
No. We set the clockwise moments about a point = anti-clockwise moments about that same point. This is rotational equilibrium.
Since the couch is in equilibrium, it must have rotational equilibrium and translational equilibrium. Translational equilibrium is all the upwards forces = all the downwards forces. Hmm, maybe i should have told you this earlier.Your numerical answers are correct. But i think you have a poor understanding of the topic.(or maybe i never explain well.)
Thank you! =] I understand it now. You explained it well, it was just my understanding. Initially, I didn't realize that this was a torque problem, lol.
What is the Center of Mass Problem?
The Center of Mass Problem, also known as the "center of gravity" problem, is a physics concept that deals with determining the point in an object where its mass can be considered to be concentrated. This point is known as the center of mass and is used to analyze the motion and stability of an object.
How is the Center of Mass Calculated?
The center of mass is calculated by finding the weighted average location of all the individual mass elements in an object. This is done by multiplying the mass of each element by its distance from a chosen reference point, and then dividing the sum of these products by the total mass of the object.
Why is the Center of Mass Important?
The center of mass is important because it allows us to simplify the analysis of an object's motion and stability. By treating the entire mass of an object as if it were concentrated at a single point, we can apply principles of physics to predict how the object will move and how it will react to external forces.
What Factors Affect the Center of Mass?
The center of mass of an object is affected by its shape, size, and distribution of mass. Objects with irregular shapes or varying mass distribution will have a different center of mass than those with uniform shapes and mass distribution. Additionally, the position and orientation of the object also affect its center of mass.
How is the Center of Mass Used in Real Life?
The center of mass is used in many real-life situations, such as designing stable structures, analyzing the stability of vehicles, and predicting the trajectory of projectiles. It is also used in sports, such as figure skating and diving, where athletes must manipulate their center of mass to perform complex maneuvers. In addition, understanding the center of mass is crucial in space exploration and satellite navigation.
