Center of mass question
  1. Oct 26, 2009 #1
    A thin rectangular plate of uniform areal density σ = 3.06 kg/m2 has length of 37.0 cm and width of 25.0 cm. The lower left hand corner is located at the origin, (x,y)= (0,0) and the length is along the x-axis.
    There is a circular hole of radius 6.50 cm with center at (x,y) = (12.50,10.50) cm in the plate. Calculate the mass of plate.
    2. Relevant equations
    3. The attempt at a solution
    I need to:
    Calculate the distance of the plate's CM from the origin.
    I've calculated the x-coordinate of the center of mass with the equation:
    x= [ ((L/2)*(l*w)) - ((2r)*pi*r^2) ] / [ (l*w) - (pi*r^2) ]
    basically x= (x-component center of mass of rectangle)*area - (center of mass of circle)*area divided by total area with L = 0.37m (length of rectangular plate), l*w= area of plate, r= 0.65m, radius of circle cut out of plate. This comes out to be 0.194m and I know is correct.
    However, I use the same equation, but replacing L with H, the height of the rectangle or 0.25m to find the y component, which I've calculated to be 0.124m. Then when I find that I used Pythagorean theorem or sqrt(x^2 + y^2) to find distance from origin to center of mass but I get a wrong answer, or answer that is supposedly wrong, which I calculate to be 0.230m. I think I'm doing it correctly, but supposedly I'm wrong, any ideas?
    EDIT: SOLVED
  3. Oct 26, 2009 #2
    Delphi51
    The method looks good. I got .195 for the x and .0555 for the y when I ran it through.
  4. Oct 26, 2009 #3
    nevermind, figured out what was wrong
Similar Discussions: Center of mass question
Loading...
