Center of mass question
  1. Sep 29, 2015 #1
    1. The problem statement, all variables and given/known data1.68 - ((51(0) + 109(1.5) + 66(3) + 13(0))/(51 + 66 + 109 + 13))
    A person with mass m1 = 51 kg stands at the left end of a uniform beam with mass m2 = 109 kg and a length L = 3 m. Another person with mass m3 = 66 kg stands on the far right end of the beam and holds a medicine ball with mass m4 = 13 kg (assume that the medicine ball is at the far right end of the beam as well). Let the origin of our coordinate system be the left end of the original position of the beam as shown in the drawing. Assume there is no friction between the beam and floor.
    1. What is the location of the center of mass of the system?
    2. The medicine ball is throw to the left end of the beam (and caught). What is the location of the center of mass now?
    3.What is the new x-position of the person at the left end of the beam? (How far did the beam move when the ball was throw from person to person?)
    4.To return the medicine ball to the other person, both people walk to the center of the beam. At what x-position do they end up?
    2. Relevant equations
    xcm = 1/MtotΣ mi*ri
    3. The attempt at a solution
    I solved number one by using the formula, I did (51(0) + 109(1.5) + 66(3) + 13(3))/(51 + 109 + 66 + 13) = 1.68.
    For the second part there is no external force so the center of mass stays the same at 1.68. It is only at #3 where I seem to go wrong.
    I thought that you had to calculate the shift by using the same equation by adjusting it to fit the new situation. So I did 1.68 - ((51(0) + 109(1.5) + 66(3) + 13(0))/(51 + 66 + 109 + 13)) = 1.68 - 1.512 = 0.167 however this answer is wrong.
    Number 4 requires number 3, so I need to figure this question out first.
    Please help
    Thank you
    Nobody wants to help ? this is due very soon. Than you for your time though.
  3. Sep 29, 2015 #2
    ehild
    0.167 m is the position of the new CM with respect to the left end of the beam. But it is shifted, and its new position is Xleft with respect to the origin, which is at the initial position of the left end. The CM is at Xleft+0.167. And you know, the position of the CM does not change. Determine Xleft.
  4. Sep 29, 2015 #3
    I don't understand is it 1.512? But isn't that the new center(not center of mass) of the system? I'm not sure how to determine x left.
  5. Sep 29, 2015 #4
    I got it all, thank you for your help!
  6. Sep 29, 2015 #5
    ehild
    Sorry, I misread your formula. You did it correctly, but miscalculated something or rounded off too early. The CM is at XCM=1.6757 m instead of 1.68. You should subtract 1.5125 from it.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Center of mass question
Loading...
