Central force w1/w2=√r2/r1
Member warned about posting without the template and with no effort
Hi
we are going through cirkular centralforce and Im complete stuck...
I cant find the derivation to why w1/w2=√r2/r1 is correct
w1/w2=√r2/r1
sorry im lost...
best regards
Fred
Answers and Replies
Dick
26,260
619
Hi
w1/w2=√r2/r1
sorry im lost...
best regards
Fred
Maybe you could explain what those symbols mean?
yes of course , sorry
There are two objects that are spinning on a plate and they fall off, and the physical reasoning is that the angular velocity (ω) has to meet the condition
ω1/ω2=√r2/r1
ω1= angular velocity objekt 1
ω2= angular velocity objekt 2
r2= objet 2 position to the center of the plate
r1= objet 1 position to the center of the plate
Best regards
Dick
26,260
619
ω1/ω2=√r2/r1
Best regards
You should probably the objects will fall of when the acceleration exceeds that which can be produced by the frictional force holding them on. Do you know that the acceleration is given by the expression ##v^2/r## where ##r## is distance from the center and ##v## is rotational speed? What's the relation between ##v## and angular velocity?
I Think that the relation is V=ωr correct? (and the friktionskoefficient is the same for both the objects)
BvU
2019 Award
13,597
3,285
That is correct. Now we need an equation to express 'staying on the plate' versus 'flying off' a bit more in physics terms using the variables in our exercise.
The template had an item for that; unfortunately it has disappeared (how ?, strange !). So here is a copy:
ω1/ω2=√r2/r1
ω1/ω2=√r2/r1
V=ωr
√r2/r1 * ω1/ω2=0
√((ω1r2)/(ω2r1))=0
hmm this doenst feel right..
Dick
26,260
619
ω1/ω2=√r2/r1
ω1/ω2=√r2/r1
V=ωr
√r2/r1 * ω1/ω2=0
√((ω1r2)/(ω2r1))=0
You haven't really done anything except for make an algebra mistake. Start from the physics. What condition will make an object fall off the plate?
BvU
2019 Award
13,597
3,285
[/B]
Object 1 lies on a spinning plate at a distance ##r_1## from the axis. It flies off at angular speed ##\omega_1## (at lower speeed it is held in orbit by friction)
Object 2 lies on the same plate at a distance ##r_2## from the axis. It flies off at angular speed ##\omega_2##.
Friction coefficients are the same for both objects.
Masses of objects may or may not be the same.
Show that ##\omega_1/\omega_2=\sqrt{r_2/r_1}##
Friction force required to stay in circular orbit F = ...
Maximum centripetal acceleration friction force can provide aat fly-off speed =
Friction force required to stay in circular orbit F = m·v2/r
Maximum centripetal acceleration friction force can provide a at fly-off speed ac =v2/r
on the right track?
Dick
26,260
619
on the right track?
Right track. Now replace the ##v## with an expression involving angular velocity.
F = m·v2/r = (m* (ωr)2)/r
ac =v2/r =(ωr)2/r
Dick
26,260
619
ac =v2/r =(ωr)2/r
Ok, now simplify that expression. ##a_c## doesn't depend on the mass, agree? So for any two objects ##a_c## is the same.
agree
(ωr)2/r = 2ω3r2
Dick
26,260
619
agree
(ωr)2/r = 2ω3r2
I don't recognize the algebra you did you get that. Can you explain?
Ohh sorry calculation fault
I dont know the name in English (kvadreringsregler) (a+b)2 = a2+2ab+b2
this one is wrong! se next one..
or the potens rule axbx=(ab)x
I am overseeing the weight i F.
ω²r=ω²r
ω²/ω²=r/r
ω/ω=√r/r
am I right ??
[/B]
Dick
26,260
619
ω²r=ω²r
ω²/ω²=r/r
ω/ω=√r/r
am I right ??[/B]
Right idea. It would look much better if you'd distinguish the two values of ##\omega## and ##r##. Start from ##\omega_1^2 r_1 = \omega_2^2 r_2##.
ω21r122r2
ω2122=r2/r1
2122)=(r2/r1)
ω12=(r2/r1)
I Think i got it right ?!
Dick
26,260
619
ω21r122r2
ω2122=r2/r1
2122)=(r2/r1)
ω12=(r2/r1)
Yes, you've got it!
Likes SwedishFred
Thanks alot sir!
we will meet again ;-)
best regards
Fredrik
Related Threads on Central force w1/w2=√r2/r1
  • Last Post
  • Last Post
24K
  • Last Post
  • Last Post
  • Last Post
16K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
