Homework Help: Central problem with l=o
  1. Jul 2, 2014 #1
    The atomic nucleus of Deuterium is a bound state of two nucleons.
    Through a change of coordinates we can transform the situation into a central force problem with a potential described by -V0 for r > R and 0 for r < R.
    In the ground state of this nucleus the angular momentum number is l=0.
    Find the binding energy of the nucleons.
    2. Relevant equations
    The radial equation: http://en.wikipedia.org/wiki/Partic...c_potential#Derivation_of_the_radial_equation
    3. The attempt at a solution
    I have two (second degree) radial equations (inside and outside of R) with different E, both with l = 0. I also have two conditions at r = R, where the two solutions and their derivatives have to be equal. I also have the normalization condition.
    That makes three constraints for four constants (plus the energy), so I can't solve it.
    I've tried adding the condition that ψ(0) = 0, because the nucleons can't be in the same place. This would allow me to find the energy inside R, which I think would be the end of the problem (since I am just asked to find the binding energy), but I'm not sure it is right, especially because doing it like this I get a solution with no dependence of V0.
    Can you tell me how to continue from here?
    Thank you for your time.
  3. Jul 2, 2014 #2
    mfb
    2017 Award
    Staff: Mentor
    Where do you get 4 constants from? Energy and amplitudes of the wave function inside and outside are 3.
    They can, they are different particle types. You can say something about ψ'(0), however.
  4. Jul 3, 2014 #3
    Three? Each one is a second-degree differential equation, so each wave function has two constants: Asin(kx) + Bcos(kx) inside and Csin(k'x) + Dcos(k'x) outside, isn't that so?
    What can I say about ψ'(0)? I'm thinking ψ'(0) = -ψ'(0), because the radial function has to be "symmetric" at each side of the 0 point, but that gives ψ'(0) = 0. Is this right?
  5. Jul 3, 2014 #4
    Yes, any other value for ψ' would produce a cusp at the origin.
  6. Jul 3, 2014 #5
    mfb
    2017 Award
    Staff: Mentor
    Ah yeah, that parametrization is better, the amplitudes would have to be complex with their relative phase as parameter... yeah use sine and cosine (or directly an exponential function for the outside area).
    Right.
Have something to add?
Draft saved Draft deleted
