What Is the Maximum Inclination Angle for Equilibrium of a Cut Square Plate?
In summary: Since you seemed resistant to figuring the angle with the object rotated in the horizontal plane with gravity vertical, I had you calculate it based on rotating gravity and viewing the object in the plane of the incline with the line that the center of mass acts through passing through the left hand...Since you seemed resistant to figuring the angle with the object rotated in the horizontal plane with gravity vertical, I had you calculate it based on rotating gravity and viewing the object in the plane of the incline with the line that the center of mass acts through passing through the left hand...The angle of inclination tolerated by the metal plate is 16 degrees.
Ulti
A uniform square metal plate of side 10 cm has a square of side 4cm cut away from one corner.
(a) Find the position of the centre of mass of the remaining plate.
It is now placed on a rough inclined plane as shown in the diagram. The place is inclined to the horizontal at an angle Θ.
(b) Calculate the maximum possible angle of inclination of the plane for the lamina to be in equilibrium.
Diagram:
http://img23.imageshack.us/img23/7048/p2103091901small.th.jpg
x bar = [tex]\frac{\sum mx}{\sum m}[/tex]
I managed to do part a) but I do not know how to do part b)
a)
x bar = (100*5 - 16*2)/84
x bar = 5.57
y bar = (100*5 - 16*2)/84
y bar = 5.57
[tex]\sqrt{10^{2}+10^{2}}[/tex]-[tex]\sqrt{5.57^{2}+5.57^{2}}[/tex] = 6.26 cm
b)
I have no idea how to work out the maximum angle if the lamina is not rectangular. Haven't been taught and can't think of where I would start. Can anyone teach me the steps in order to work it out?
Thanks in advance!
Hi Ulti
The plate will start to topple when a line drawn vertically through the centre of mass falls outside the base support
This is equivalent to calculating the net torque on the plate due to the gravitational & reaction forces. When a line drawn vertically down through the centre of mass falls inside the base support, the net torque will sum to zero (ie it is in static equilibrium).
When a line drawn vertically through the centre of mass falls outside the base support, the net torque is no longer zero and the plate is unstable & will move.
Thanks for the answer, I've done the rest of the questions which is the same but with a rectangular lamina and I just drew a rectangle from it and used the inverse of tan to calculate it.
I'm not too sure on how to calculate the moments (I assume you mean that by "torque") in this kind of situation... Am I missing something very fundamental here?
You don't need to calculate the torque. It is enough to know the angle of inclination tolerated by observing what angle a line from the down incline corner of the base through the center of mass (x,y) makes with the vertical.
The center of mass requires a support along the line that is in the direction of gravity.
If I draw a line from the centre of mass to the direction of gravity I still don't see how I can work out the angle. I believe I can use trigonometry somewhere but I fail to see where I can apply it...
What is the coordinate of the base corner that would be furthest down the incline?
Then what is the coordinate of the Center of Mass?
The difference in the x coordinate divided by the y-height of the center of mass is the tan-1 of the angle.
That would be (0, 4)
(5.57, 5.57)
The difference in the x coordinate divided by the y-height of the center of mass is the tan-1 of the angle.[/QUOTE]
tan-1 [tex]\frac{5.57-4}{5.57}[/tex] = 16 = Right answer!
Thanks! One thing I still don't understand is how this gave me the right answer though...
hi Ulti
what don?t you understand? if you re-read the posts I think its been explained (i made some corrections to my earlier one wher i had some typos as well)
the angle is calculated when the centre of mass is directly above the left base corner, which is what you calculated...
Since you seemed resistant to figuring the angle with the object rotated in the horizontal plane with gravity vertical, I had you calculate it based on rotating gravity and viewing the object in the plane of the incline with the line that the center of mass acts through passing through the left hand corner.
Ah I understand now! Thanks for all the help! Now I can do the rest of this exercise with ease. Thanks once again!
What is the centre of mass?
The centre of mass is a point where the entire mass of an object can be considered to be concentrated.
How is the centre of mass calculated?
The centre of mass is calculated by finding the weighted average of the positions of all the individual particles that make up the object.
What is toppling?
Toppling is a type of motion in which an object loses its balance and falls over due to the force of gravity acting on its centre of mass.
What factors affect the stability of an object's centre of mass?
The stability of an object's centre of mass is affected by its shape, distribution of mass, and the location and direction of external forces acting on it.
How can an object be prevented from toppling?
An object can be prevented from toppling by increasing its base of support, lowering its centre of mass, or by adding external supports or anchors to counteract the force of gravity.
16K
