Centre of mass
  • Thread starter vintwc
Let Ω be a tank whose shape is that of the lower hemisphere of radius R. The tank with a muddy suspension whose density ρ is ρ(x,y,z):=e^-h(x,y,z), where h(x,y,z) is the height of (x,y,z) above the lowest point of the tank. Find the center of mass in the tank
First of all, how does one determine the height, h(x,y,z)? I guess it would be R but I am not able to give a reasoning to my guess. I would appreciate if someone could give me a graphical illustration on how to find the limits of integration for this problem as well. Thanks
Answers and Replies
Alright following the my notes so far which had a sort of similar but different question, I guess that the height is z+R? Assuming if this is right, the limits of integration will be [0,R]x[-Pi/2, 0]x[0,2*Pi] (since we are looking at the lower hemisphere).
However, if I try to calculate the first moments M_yz, I got the integrand as 0 at some point. Maybe this indicates that I am moving in the wrong direction?
HallsofIvy
41,847
969
If you set this up so the hemisphere is the lower half of a sphere of radius R with center at (0,0,0), then the lowest point is (0, 0, R) and the "height above the lowest point" of (x,y,z) is R+ z (z is negative, of course).
[tex]e^{-h}= e^{-R-z}= e^{-R}e^{-z}[/tex].
The equation of the hemisphere is [tex]z= \sqrt{R^2- x^2- y^2}[/tex].
Squaring both sides of that gives [itex]x^2- y^2= z^2- R^2[/itex] which is the equation of a cross section of the hemisphere at that height. Since the density is a function of z, that will be helpful in integrating. Since that is a circle for all z, I would recommend doing the integration in cylindrical coordinates.
Ah, too late for correction. But I had the same approach as yours. I was considering cylindrical coordinates but I was having trouble with finding the limits (spherical one as well).
Related Threads on Centre of mass
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
