Help Solving Physics Problem with Diagram Attached
In summary, the conversation discusses a problem from a physics textbook involving a rope passing over a smooth peg, and the person's attempts to solve it using conservation of energy and equations of motion. The concept of the center of mass is not as helpful in this case because the rope is not rigid, and using the end of the rope as the reference point is more appropriate. The person also expresses some discomfort with not being able to use the center of mass to solve the problem and asks for further clarification.
pab123
Please could someone help me with the following.
I have attempted to attach a simple diagram drawn using "Paint".
This problem is taken from Fundamental University Physics Volume 1 second edition by Alonso & Finn page 184 Q7.83:
"A uniform (rope) of mass M length L passes over a smooth peg of very small radius. When the motion starts, BC=b. Show that the accelaration and velocity when BC=(2/3) L are a=g/3 and v=√[(2g/L)((8/3)L²+2bL-b²)].
Apply your results to L=12m and b=7m.
Please refer to attached diagram - the long piece which descends is BC=b initially in case you have difficulty viewing.
My first idea was to use conservation of mechanical energy. If I can calculate the centre of mass then I can equate loss of potential energy U with gain in kinetic energy K.
Calling the length of the long side x the mass of this is (M/L)x with centre of mass at (1/2)x. Similarly the short side of length (L-x) has mass (M/L)(L-x) with centre of mass (1/2)(L-x). Adding and dividing by total mass M I obtain the centre of mass of the system to be:
(1/2L)(L²-2xL+2x²)
I then substitute b for x and (2/3)L for x and taking the difference between the two obtain:
U = (1/2L)Mg((4/9)L²-2bL+2b²)
K = (1/2)Mv²
K+U=0
v=√[(2g/L)(bL-b²-(2/9)L²)]
Not the book solution but if I use the numbers given then the book answer suggests v=28.6m/s whereas my solution is a more reasonable v=√(g/2) =2.2m/s.
In order to verify my answer I tried to solve the equation of motion. This is where my problem lies.
I consider the two sides separately again with the centre of mass of the long side at y1, length 2y1, mass (M/L) 2y1 and the centre of mass of the short side at y2, length 2y2, mass (M/L) 2y2. The differential equations are then:
g(M/L) 2y1 - T = (M/L) 2y1 d²y1/dt²
g(M/L) 2y2 - T = (M/L) 2y2 d²y2/dt²
where T is tension in the rope. Additionally we have:
2y1 + 2y2 = L so that:
d²y2/dt² = - d²y1/dt²
I can now eliminate y2 and then T leaving the following differential equation:
d²y1/dt² -(4g/L) y1 = -g
A particular solution is y1 = L/4
The homogeneous equation is solved by standard techniques and my general solution is:
y1 = Ae^(t√(4g/L)) +Be^(-t√(4g/L)) + L/4 with y1=(1/2)b and dy1/dt=0 at t=0
Hence A=B=(1/8)(2b-L) and so:
y1 = (1/8)(2b-L)(e^(t√(4g/L)) + e^(-t√(4g/L))) + L/4
or y1 = (1/4)(2b-L)cosh(t√(4g/L)) + L/4 position
so dy1/dt = (1/4)(2b-L)√(4g/L)sinh(t√(4g/L)) speed
and d²y1/dt² = (1/4)(2b-L)(4g/L)cosh(t√(4g/L)) accelaration
I can solve the last equation when accelaration is (g/3), b=7m L=12m as required by the question to get cosh(t√(4g/L)=2 hence sinh(t√(4g/L))=√3 and speed is then dy1/dt= √(g/4) m/s.I now recognise that for every 2m the rope descends then in the same time interval the centre of mass moves only 1m and therefore travels at half the speed of the rope. My answer therefore is that when the accelaration is (g/3) the speed is 2√(g/4) or √g m/s. Recall that using energy I obtained a speed of v=√(g/2) m/s.
Trying to eliminate the factor of root two I tried the following.
Abandon centre of mass. Call the end of the long piece y. Mass is y(M/L) and then the mass of the short piece is (L-y)(M/L). The equations of motion then become:
g(M/L) y - T = (M/L) y d²y/dt²
g(M/L) (L-y) - T = -(M/L) (L-y) d²y/dt²
Subtracting and rearranging:
d²y/dt² - (2g/L) y = -g
A particular solution is y = L/2
y = Ae^(t√(2g/L)) +Be^(-t√(2g/L)) + L/2 with y=b and dy/dt=0 at t=0
Hence A=B=(1/4)(2b-L) and so:
y = (1/4)(2b-L)(e^(t√(2g/L)) + e^(-t√(2g/L))) + L/2
or y = (1/2)(2b-L)cosh(t√(2g/L)) + L/2 position
so dy/dt = (1/2)(2b-L)√(2g/L)sinh(t√(2g/L)) speed
and d²y/dt² = (1/2)(2b-L)(2g/L)cosh(t√(2g/L)) accelaration
I can solve the last equation when accelaration is (g/3), b=7m L=12m as required by the question to get cosh(t√(2g/L)=2 hence sinh(t√(2g/L))=√3 and speed is then dy/dt= √(g/2) m/s in agreement with the solution using energy and confirming the book answer is incorrect.
I am uncomfortable with not being able to use my first set of equations of motion to solve this problem. I was under the impression that whenever we have an extended body, we write the equation of motion as though all forces are applied at the centre of mass and the solution tells us how the centre of mass moves. In this case it seems that concept is unhelpful and a choice of the end of the rope is better, an exception to the rule which is hard for me to understand. An immediate thought is how do I spot this next time around in a problem? Whilst this is not a rigid body problem, I thought the speed of the centre of mass and the speed of the physical rope were different by a factor of two, not root two, but I am unable to reconcile the difference between my results.
Any help would be appreciated. Thanks.
It looks like you have done a good job of solving this problem. In this case, the concept of the center of mass is not as helpful as it usually is, because the rope is not rigid. That is why it is better to choose the end of the rope as your point of reference. When dealing with extended bodies, you should always take into account whether or not the body is rigid. If it is rigid, then the center of mass should be used as the reference point. But if the body is not rigid, then it is better to use the end of the body as the reference point. The difference between your two results is due to the fact that when you used the center of mass as your reference point, the speed of the center of mass was half the speed of the physical rope. But when you used the end of the rope as your reference point, the speed of the rope and the speed of the center of mass were the same.
1. How do I approach solving a physics problem with a diagram attached?
First, carefully examine the given diagram and identify all the relevant information, such as values of variables, known quantities, and the physical relationships between them. Then, choose an appropriate equation or set of equations that can be used to solve for the unknown quantity. Finally, plug in the known values and solve for the unknown using algebraic manipulation or a calculator.
2. What should I do if I am stuck on a step while solving a physics problem with a diagram attached?
If you are stuck on a step, take a step back and review the given information and your approach. Double-check the accuracy of the diagram and the values you are using. If necessary, consult your textbook or class notes for relevant equations or examples. You can also ask a classmate or your instructor for assistance if you are still having trouble.
3. Can I use different methods to solve a physics problem with a diagram attached?
Yes, there are often multiple ways to approach and solve a physics problem with a diagram attached. Some methods may be more efficient or straightforward depending on the given information. You can also use a combination of methods, such as using equations and kinematic graphs, to solve a problem. The key is to choose a method that you are comfortable with and that helps you arrive at the correct answer.
4. How can I check if my solution to a physics problem with a diagram attached is correct?
To check your solution, you can use the given information and your answer to see if they align with the physical principles and relationships involved in the problem. You can also try plugging your solution back into the original equation to see if it yields the same result. Additionally, you can compare your answer to a classmate's or check with your instructor to confirm if your solution is correct.
5. Are there any tips for solving a physics problem with a diagram attached more efficiently?
Yes, here are a few tips that may help you solve a physics problem with a diagram attached more efficiently: 1) Make sure you clearly understand the given information before attempting to solve the problem. 2) Use the given diagram to your advantage and label any important information to help guide your approach. 3) Break down the problem into smaller steps if it seems overwhelming. 4) Practice solving similar types of problems to become more familiar with the methods and equations involved. 5) Don't be afraid to ask for help if you are struggling with a problem.
