• Support PF! Buy your school textbooks, materials and every day products Here!
Centripetal Force problem
  • Thread starter John H
I'm having a hard problem conceptualizing this. It states that an object with a certain Mass M is being spun in a vertical circle. The object attached to a rope, and the object moving in circular path with constant radius. It also give you the velocity of the object. It asks you to find the tension force when the object is sideways. like the diagram blow. Note velocity is constant, object has uniform circular motion.
[PLAIN]http://img543.imageshack.us/img543/5048/object.jpg [Broken]
The actual numbers dont matter to me, the book solves the problem by simply stating that the centripetal force comes from the tension, ignoring gravity, which correct, since gravity provides no force in this case along the radius. Here is where the book absolutely makes no sense, it obtains a tension by using the Fc = mv^2/r. Which is correct, but shouldn't this only be the tension in the x-component. Because a y-component of tension is required to to hold the object.
Thanks in advance.
Now my theory is that the object has enough velocity, so that it can mover vertically upwards after coming downwards that the tension force required in y-component is negligible.
Answers and Replies
PhanthomJay
475
No, the error here is in your initiial premise that the mass is moving with constant velocity in uniform circular motion. If there is a net force of gravity acting downward, what does this imply?
Sorry, I should have stated constant speed. Still I cant see how that would solve the problem.
PhanthomJay
475
It is not moving at constant velocity. Neither is it moving at constant speed. A particle moving in a vertical circle does not move at constant speed or constant velocity unless there is some external non conservative force or torque acting on it that does work. Draw a free body diagram of the object in the position shown. Again, you should note that there is a vertical force in the downward y direction that is not balanced by any other force in the upward y direction. What does Newton 2 say about net forces acting on an object?
Related Threads for: Centripetal Force problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
