Centripetal forces
  1. Mar 17, 2014 #1
    A 1.5 kg mass tied to the roof rotates with constant speed in a horizontal
    circle. The string makes an angle of 30 deg to the vertical.
    a) determine the velocity , the centripetal acceleration and the centripetal
    force on the mass.
    b) determine the tension in the string.
    c) say the mass is given a push so that now the mass rotates with a constant
    velocity of 9.4 m/s . Determine the angle the string makes with the vertical
    , the centripetal force on the mass and the tension in the string.
    2. Relevant equations
    ∑Fradial = TsinΘ = mv2/R
    ∑Fy = TcosΘ - mg = 0
    3. The attempt at a solution
    To solve part a:
    First I found my R by,
    R = LsinΘ = 1.5sin30° = .75m
    Second my T by,
    T= mg/cosΘ = 1.5*9.8/cos30° = 16.97 N
    Now I find my velocity by,
    V= sqrt((R*T*sinΘ)/m)) = sqrt((.75*16.97*sin30°)/1.5) = 2.06 m/s
    the centripetal acceleration,
    v2/R = a
    a = TsinΘ/m = 16.97*sin30°/1.5 = 5.66 m/s2
    for part b I already found my tension to be 17N.
    Part C is where I am having trouble, how can i find the angle Θ with the new constant velocity if im not given a radius or tension?
  3. Mar 17, 2014 #2
    TSny
    2017 Award
    Hello, mpittma1. Welcome to PF!
    Note that you have 3 "unkowns": θ, T, and R. But you also have 3 equations: your two "Relevant equations" and your equation for R in terms of L and sinθ.
    Can you see how to do the algebra to get to an equation where the only unknown is θ?
  4. Mar 17, 2014 #3
    Hey TSny,
    So my three equations are:
    R = LsinΘ (1)
    TcosΘ - mg =0 (2)
    TsinΘ = mv2/R (3)
    I see how you could plug equation 1 into equation 2 and come up with
    TsinΘ = mv2/LsinΘ which is closer because I have my m, v, and L but Im still not seeing how to get rid of the T by using equation 2.
  5. Mar 17, 2014 #4
    TSny
    2017 Award
    Use (2) to find T in terms of θ. [EDIT: Or divide (3) by (2) after rearranging (2)]
  6. Mar 17, 2014 #5
    So I am coming up with:
    TanΘ = v2/LsinΘg
    after dividing eqn 3 by eqn 2 and plugging in eqn 1 for R.
    After doing some more algebra I come up with tanΘsinΘ = v2/Lg
    something doesnt seem right there though....... how could i solve for tanΘsinΘ?
  7. Mar 17, 2014 #6
    TSny
    2017 Award
    Looks good so far! Can you express the left side of the equation solely in terms of sinθ?
  8. Mar 17, 2014 #7
    well I could easily express the left side as sin2Θ/cosΘ
    im not seeing how to express it solely as sinΘ though
  9. Mar 17, 2014 #8
    TSny
    2017 Award
    Can you think of a trig identity that relates sinΘ and cosθ?
  10. Mar 17, 2014 #9
    so heres what im doing:
    sin2Θ/cosΘ → using a half angle formula (1-cos2Θ)/2 * 1/cosΘ →
    (1-cos2Θ)/2cosΘ
    my eqn thus far is (1-cos2Θ)/cosΘ = 2v2/Lg
    how could you simplify the left side further?
  11. Mar 17, 2014 #10
    TSny
    2017 Award
    I'm not sure the half-angle formula will help. Can you make use of sin2Θ + cos2θ = 1?
    [Edit: I said earlier to express everything in terms of sinθ, which will work. But it might be a little easier to express sin2Θ/cosΘ in terms of cosθ.]
  12. Mar 17, 2014 #11
    I was trying to find a way to get a +cos2Θ but its just not there
  13. Mar 17, 2014 #12
    TSny
    2017 Award
    So, use the trig identity to express sin2θ in terms of cos2θ.
  14. Mar 17, 2014 #13
    (1-cos2Θ)/cosΘ
    or secΘ-cosΘ so im almost there
  15. Mar 18, 2014 #14
    TSny
    2017 Award
    Good
    I don't recommend writing it this way. Use (1-cos2Θ)/cosΘ for tanθsinθ in your equation from post #5 and see if you can proceed from there.
  16. Mar 18, 2014 #15
    After plugging in my values for v L and g i get:
    (1-cos2Θ)/cosΘ = 6.011
    any suggestions any solving for Θ?
  17. Mar 18, 2014 #16
    TSny
    2017 Award
    Let x = cosθ and write your equation in terms of x. Can you solve for x?
  18. Mar 18, 2014 #17
    ok so what i did:
    let x = cosΘ
    so, 1-x2/x = 6.011
    1-x2 = 6.011x
    0 = x2 + 6.011x -1
    then after solving for the roots of x
    x = -6.173 and .162
    plugging x = .162 into x = cosΘ
    gives me Θ = 80.7° which is the correct answer!!!
    thank you for all your help!
  19. Mar 18, 2014 #18
    TSny
    2017 Award
    Good work!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Centripetal forces
  1. Centripetal force (Replies: 6)
Loading...
