Centripetal motion and universal gravitation question: Mars and Sun question
In summary: So [m kg^2]/[N s^2] = [m kg^2]/[(kg-m/s^2)(s^2)]= [m kg^2]/[kg-m]= [m kg^2]/[kg-m]= [m kg^2*m]/[kg]= [m^3*kg]/[kg]= [m^3].So your final answer for the mass of the Sun should be in units of meters cubed (m^3).In summary, Mars travels around the Sun in 1.88 Earth years in an approximately circular orbit with a radius of 2.28 x 10^8 km. The orbital speed of Mars relative to the
zeion
466
Mars travels around the Sun in 1.88 (Earth) years, in an approximately circular orbit with a radius of 2.28 x 10^8 km
Determine
a) the orbital speed of Mars (relative to the Sun)
b) the mass of the Sun
acceleration centripetal = 4(pi^2)(r) / (T^2)
universal attraction = (G)(m1)(m2) / (radius)^2
Given:
T = 1.88 years = 59287680s = 5.9x10^7s
r = 2.28 x 10^8km = 2.28 x 10^11m
Orbital speed means centripetal acceleration yes?
Then,
acceleration centripetal = 4(9.869604401)(2.28x10^11m) / (34.81x10^14s)
acceleration centripetal = 90.01x10^11m / 34.81x10^14s
acceleration centripetal = 2.59x10^-3m/s = 0.00259m/s
How come its so slow?
No. Speed is distance divided by time, not acceleration.
Ok so,
Mars travels around the Sun once every 1.88 years. So I have to find the distance of that circle and divide it by the time to find the speed. I have the radius, so I have to find the perimeter.
Perimeter of circle is 2(pi)(r)
So the distance traveled is 14.33x10^11m
In 1.88 years = 5.9x10^7s
So the speed is 14.33x10^11m / 5.9x10^7s = 2.43x10^4m/s yes?
Good.
Now can I use this formula to solve for mass of Sun?
V^2 = (G)[m1(sun)] / r
[m1(sun)] = (V^2)(r) / (G)
[m1(sun)] = (2.43x10^4m/s)^2(2.28 x 10^11m) / [6.67x10^-11(N)(m^2)/kg^2]
[m1(sun)] = (5.9x10^8m^2/s^2)(2.28 x 10^11m) / [6.67x10^-11(N)(m^2)/kg^2]
[m1(sun)] = (13.45x19^19m^3/s^2) / [6.67x10^-11(N)(m^2)/kg^2]
[m1(sun)] = 2.02x10^8(N)m/kg^2
Why are the units all weird?
Good.
In your last step you didn't divide the units properly. You should have gotten:
[m^3/s^2]/[(N)(m^2)/kg^2] = [m^3/s^2]*[kg^2/(N)(m^2)] = [m kg^2]/[N s^2]
To simplify further, express Newtons in terms of more fundamental units:
N = kg-m/s^2
1. What is centripetal motion?
Centripetal motion is a type of motion in which an object moves in a circular path around a center point, while experiencing a force directed towards the center of rotation. This force is necessary to keep the object moving in a curved path instead of a straight line.
2. How does universal gravitation apply to Mars and the Sun?
Universal gravitation is the force of attraction between any two objects with mass. In the case of Mars and the Sun, the Sun's mass creates a gravitational force that pulls Mars towards it, causing Mars to orbit around the Sun.
3. What is the relationship between centripetal force and universal gravitation?
Centripetal force is necessary for an object to maintain circular motion, while universal gravitation is the force that causes this motion. In the case of Mars and the Sun, the Sun's gravitational force acts as the centripetal force on Mars, keeping it in orbit.
4. How does the distance between Mars and the Sun affect their gravitational pull?
The distance between Mars and the Sun affects their gravitational pull through the inverse square law. This means that as the distance between two objects increases, the force of gravity between them decreases. Therefore, the farther Mars is from the Sun, the weaker the gravitational pull between them.
5. Why does Mars have a longer orbital period around the Sun compared to Earth?
Mars has a longer orbital period around the Sun compared to Earth because it is farther from the Sun and therefore has a larger orbit. This means that Mars takes longer to complete one revolution around the Sun, resulting in a longer orbital period.
