Centripetal things
How do you find the place when the ball is about to "swing" out?
A ball is attached to a vein, which has max tension of 300N; and Hercules is swinging the vein above his head. The length from vein to ball is .8meters. The ball has mass of 1.2kg..
How do you find the velocity of the ball just before it swings out?
Please advise... Thanks you!
Doc Al
Mentor
44,642
966
What's a vein? Do you mean chain?
In any case, here's a hint: The max tension is also the max centripetal force that can be supplied.
BobG
The ball will escape when it's 'centripetal force' is greater than the max tension of the vein.
Hopefully, you know that Force = Mass * Acceleration.
If you know your max 'centripetal force', then you can calculate your max centripetal acceleration.
Knowing your max centripetal acceleration and your radius, you can calculate your max velocity.
Centrepidal force is = mv^2/r,
but i dunno my velocity... What is another way to find Centrepedal force?
The only force in the x direction is the Tension force in the x component...
But i dunno that.
Is this right? :
Fc = 300
mv^2/r = 300
v = sqrt (300R/m)
Doc Al
Mentor
44,642
966
You got it.
aha! Thanks!!!! That was sooo much simpler than I thought...
But... how can we do this based on FreeBody Diagram?
There's 2 forces: Tension and Gravity right?
And Tension has 2 components: x and y.
Any advise on how I should draw the free body diagram?
and at what position is the ball when it is about to fall out?
Do i use V^2 = V0^2 + 2ax? What is its final speed? 0?
Doc Al
Mentor
44,642
966
I've been assuming that the ball travels in a horizontal circle. To give you a better answer, I'd need to see what this apparatus looks like. Do you have a picture?
your assumption is right. it is just a plain circle.
Doc Al
Mentor
44,642
966
If the ball is travelling in a horizontal circle, and the tension in the "vein" (what's a vein?) is also horizontal, then the problem ignores gravity. You've already solved the problem.
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
