Find Centroid of Parabola Bounded by x Axis
In summary, a centroid is the geometric center of a shape or object, and is also known as the center of mass. A parabola is a curve created by the intersection of a plane and a cone, and its centroid is calculated using the formula x = (2a/3) and y = (2a^2/3). The centroid of a parabola bounded by the x-axis is significant in determining the center of mass and point of equilibrium in a system. A parabola can only have one centroid, located at the point of intersection between its axis of symmetry and the parabola.
Jbreezy
582
y = 16 -x^2 find centroid bounded by x axis
x = (1/A) ∫ x(f(x)) dx and (1/A) (1/2)(f(x))^2 dx = y
I just applied it. It is a weird because I would of thought that x would of been at 0. But I didn't get that I x = 9/16 and y = 8/5. Y might be OK but wouldn't x have to be at 0?
I calculated the area I got 256/3
So x = (3/256) ∫(x(16-x^2) dx = (3/256)∫ 16x - x^3 dx = (3/256) (8x^2 -(x^4/4)) between [-4,4] = 9/16
For y = (3/256) ∫ (1/2)(16-x^2)^2 dx = (3/256)∫ 256 - 32x^2 + x^4 dx = (3/512)(256x = (32/2)x^3 - (x^5/5)) between [-4,4] = 8/5
Like I said it seems that x would be at 0 but I'm not sure I think I did everything OK.
Your intuition is correct, but your work isn't. ##\bar{x}## = 0, which is pretty obvious from the symmetry of the region.
So, Even though it is the long way if I did it the way I did it should workout to be 0. Why do I get what I get ? did you look at y ? What did you think of y?
I found my mistake for x. Do you think y looks OK I went over it again seems OK to me.
Your integral doesn't look right to me. It should be
$$\frac 1 A \int_0^{16} y * (x_{right} - x_{left}) dy$$
The integrand represents the moment of a horizontal strip across the parabola, and the moment in this case is the length of the lever arm (y) times the area of the horizontal strip ΔA = (xright - xleft)Δy.
Your function is y = 16 - x2, or equivalently, x = ±√(16 - y).
Part of your problem seems to be treating x and y cavalierly - you can't do that and come up with the right answer.
With all of these applications of integration, it's extremely helpful to have a good drawing of the situation. Just memorizing some formulas and using them blindly isn't a good strategy.
##\frac 1 A \int_0^{16} (1/2)[f(x)]^2 dx##
This is what my book gives for calculation of y. I don't understand your formula. Well I do but why would I need to deviate from what the book says for this problem. I don't see why?
Your formula should be ##\frac 1 A \int_{-4}^{4} (1/2)[f(x)]^2 dx##, with the difference being the limits of integration. You're integrating with respect to x, and x is in the interval [-4, 4].
With that correction, your formula and mine should agree. The difference between them is that my formula uses horizontal strips that extend across the parabola. For each of these the lever arm is the y value on the strip. Each of my horizontal strips is very narrow, so all the strips have about the same y value. In my formula, the moment is y * <width of strip> * Δy.
Your formula uses vertical strips of height f(x). The lever arm is at the middle of the strip, so is (1/2)f(x). The moment is f(x) * (1/2)f(x) * Δx.
I meant [-4,4] I forgot to change it. Yeah I recalculated y with my formula and I got 32/5.
In yours what is x left and right? Would it be after subtracting.
##\frac 1 A \int_0^{16} y * (2\sqrt(16-y)) dy##
The books formula is right. It's an equivalent formulation. To show they are the same you use Green's theorem.
Yes, or you can explain it that way instead of using Green's theorem. Actually somewhat nicer.
Pretty out there though for me.
What class out greens theorem come up/
Would*
Vector calculus, but I wouldn't worry about it. Mark44's explanation is fine and much more elementary.
What is the definition of a centroid?
A centroid is the center of mass or geometric center of a two-dimensional shape or three-dimensional object. It is the point at which the shape would balance if it were cut out of a material.
What is the formula for finding the centroid of a parabola bounded by the x-axis?
The formula for finding the centroid of a parabola bounded by the x-axis is (2a/3, 2a/5), where 'a' is the distance from the vertex to the focus of the parabola.
Can the centroid of a parabola bounded by the x-axis be located outside of the parabola?
No, the centroid of a parabola bounded by the x-axis will always be located within the boundaries of the parabola. This is because the centroid is a point of balance and cannot exist outside of the shape.
How does the value of 'a' affect the location of the centroid of a parabola bounded by the x-axis?
The value of 'a' affects the location of the centroid by determining the distance of the centroid from the vertex of the parabola. A larger value of 'a' will result in a centroid that is further away from the vertex, while a smaller value of 'a' will result in a centroid that is closer to the vertex.
Is there a visual way to find the centroid of a parabola bounded by the x-axis?
Yes, one way to visually find the centroid of a parabola bounded by the x-axis is by balancing the shape on a point. This can be done by placing a pencil or ruler at the approximate location of the centroid and adjusting it until the shape is balanced.
