Ceramic Disc Thermal Conductivity: Exploring K Values and Applications
In summary, the conversation is about finding information on the type of ceramic used in car brake discs and its thermal conductivity. The person asking for information was directed to do a Google search for "brake disk pad ceramic thermal constant" and "brake disk pad ceramic type" to find relevant articles and discussions. It was suggested to either purchase a paper or try to find old brake pads to measure the thermal conductivity. However, it was mentioned that the material mix details may be kept proprietary by manufacturers. The person was grateful for the help and found the new search results helpful.
heiroglif
Hi id just like some info on the type of ceramic used in car brake discs and where i can find its thermal conductivity K?
Thanks!
I googled brake disk pad ceramic thermal constant, and got some promising hits. Here's the hit list:
http://www.google.com/search?hl=en&q=brake+disk+pad+ceramic+thermal+constant
The paper in the first hit looks useful, but I think you have to pay for it. You might click through a few of the other hits to see if they have the quantitative thermal info you need. Worst case you could get an old brake pad from your local workshop where they service brakes (I'm sure they have some old ones that they were going to throw away), and do the measurement yourself.
i mean if someone know the actual type of ceramic i could find its thermal K,
i know there's different types, so i just want to find the right one...
thanks for your reply
ok...yeah that looks good...thanks for the help
1. What is a ceramic disc thermal K?
A ceramic disc thermal K is a type of thermocouple, which is a device used to measure temperature. It is made of two different types of ceramic materials that are joined together to create a voltage difference when exposed to heat. This voltage difference can then be measured and used to accurately determine the temperature.
2. How does a ceramic disc thermal K work?
A ceramic disc thermal K works based on the Seebeck effect, which is the creation of a voltage difference when two dissimilar materials are connected. In this case, the two ceramic materials have different electrical properties, so when exposed to heat, a voltage difference is created that can be measured and converted into a temperature reading.
3. What are the advantages of using a ceramic disc thermal K?
One of the main advantages of using a ceramic disc thermal K is its high temperature resistance. It can withstand high temperatures up to 1400°C, making it suitable for use in extreme environments. It also has a fast response time and is highly accurate, making it a reliable choice for temperature measurement.
4. Where is a ceramic disc thermal K commonly used?
Ceramic disc thermal Ks are commonly used in industrial applications, such as in furnaces, kilns, and ovens, where high temperatures need to be monitored and controlled. They are also used in laboratory settings and in scientific research for precise temperature measurement.
5. How do I choose the right ceramic disc thermal K for my application?
Choosing the right ceramic disc thermal K depends on factors such as the temperature range and accuracy required for your specific application. It is also important to consider the type of environment the thermocouple will be used in and the size and shape of the ceramic disc. Consulting with a specialist or supplier can help ensure you select the best option for your needs.
  • Materials and Chemical Engineering
