Converting Between MKS and CGS Unit Systems: Tips and Tricks?
In summary, CGS units are difficult to convert between, and can result in incorrect calculations if the equations are different.
enricfemi
195
"cgs" unit systems
i'm used to mks unit systems, but i have to read a book with cgs recently.
it's difficult for me to transform it between them.
can anyguys give me some advises to deal with it !
thanks for responds!
Distances are a 100x bigger than they should be, masses are 1000x
The electric field equations are generally missing a 2pi
At least seconds are the same!
CGS is still very common in astronomy
yes,that's right.
but i want know how should i deal with it.
should i transform the CGS formulas to MKS or directly deduce in CGS,or someother manner.
The appendix in Jackson gives a good review of various units. I've never found shifting between units to be a big deal myself.
enricfemi said:
yes,that's right.
The easiest thing, for me at least, is to work in whatever units you want the result to be in when finished. If you're writing for a paper, for instance, that wants things in CGS, then start in that format. It's a lot easier than doing it in other units and then translating it. If you're just doing something for yourself, then use whatever you're most comfortable with.
But it still creates a lot of problems. Just last week a colleague of mine was reading two papers where the respective authors got different results after performing nominally identical experiments. After a while she realized that the reason was that there was a 2pi missing in a formula in one of them; the authors were -apparently without realizing it- using a formula taken from a book written using cgs units but the experimental data and all the other formulas were in SI. Hence, when they fitted their data they came to the wrong conclusion.
A silly misstake, but sometimes it is far from obvious that there is a 2pi missing in a complicated expression (I have made the same misstake using the same book, but fortunately never in anything that I have published).
It can be very confusing- MKS, CGS, 'natural', Gaussian, etc. etc. My only advice is not to get bogged down in the details; like always trying to convert miles-per-hour to m/s. Instead, focus on the concepts, get used to doing dimensional analysis, stuff like that.
This is easy at the condition that the equations are the same in the two systems of units, i.e. that the factors are the same. However when the equations are different (like different factors of [tex]2 \pi, \epsilon_0[/tex] ,etc) then it's a pain in the neck because every time you use a formula that you remember from undergraduate physics, you never know if it's still valid in those other units (example: you calculate the B field produced by an infinite wire and you are in cgs...can you use [tex] \frac{\mu_0 I}{2 \pi r}[/tex], you wonder...)
I personally prefer to convert all the information given to SI units, calculaet everything with formula I know and cherish and convert back to cgs at the end.
But it's a matter of taste.
The key point is to know or to have handy all the equations required in the system of units one is working with.
Very good point, Kdv; I never even thought of the formulae changing. :redface:
1. What is the CGS unit system?
The CGS unit system is a system of measurement commonly used in scientific fields. It stands for centimeter-gram-second and is based on the centimeter for length, the gram for mass, and the second for time.
2. How does the CGS unit system compare to other unit systems?
The CGS unit system is one of three commonly used unit systems in science, alongside the MKS (meter-kilogram-second) system and the FPS (foot-pound-second) system. It is smaller and less commonly used than the MKS system, but is still used in certain scientific fields.
3. What are some examples of commonly used CGS units?
Some examples of commonly used CGS units include centimeters for length, grams for mass, and dynes for force. Other units include ergs for energy, poises for viscosity, and baryes for pressure.
4. Are there any benefits to using the CGS unit system?
One benefit of the CGS unit system is that it is often easier to work with for calculations in certain scientific fields, such as electromagnetism. Additionally, some equations and laws in physics are written in CGS units, making it necessary to use this system in those cases.
5. How can I convert from CGS units to other unit systems?
To convert from CGS units to other unit systems, you can use conversion factors or online conversion tools. Keep in mind that the conversion factors may vary depending on the specific units you are converting. It is important to double check your conversions to ensure accuracy.
  • Other Physics Topics
20K
