Chain rule app.
  1. Dec 6, 2007 #1
    Let [tex]y=\sqrt{x+f(x^2-1)}[/tex]. Find [tex]\frac{dy}{dx}[/tex] when x=3, given that [tex]f(8)=0[/tex] and [tex]f'(8)=3[/tex].
    I missed the lesson for this and am lost on what to do. some guidence would be appreciated. i dont understand the [tex] f(x^2-1) [/tex] inside the bracket.
  3. Dec 6, 2007 #2
    i spent like an hour trying to figure this out. (need to not miss class!)
    my attempt at a solution:
    this this anywhere near correct? can someone inform me where i went wrong? right of the bat? inbetween??
  4. Dec 6, 2007 #3
    You're very close. However, you forgot to apply the chain rule when you took the derivative of [tex]f(x^2 - 1)[/tex]. That, too, is a composition of function and so you must also apply the chain rule when taking its derivative.
  5. Dec 6, 2007 #4
    am not sure i understand but...would its derivative be[tex]\frac{1}{f(x^2-1)}[/tex]? or could t be [tex]f'(x^2-1)(2x)[/tex]
  6. Dec 6, 2007 #5
    Not quite. Remember that the chain rule says
    When you have
    [tex]f(x^2 - 1)[/tex]​
    They're saying that, rather than plugging in the usual x in your variable, you plug in [tex]x^2 - 1[/tex]. For example, let [tex]f(t) = t^2[/tex]. Then, [tex]f(x^2) = (x^2)^2 = t^4[/tex]. So, you have a composition of functions, where, using the notation of the chain rule as stated above,
    [tex]f(x) = f(x)[/tex]
    [tex]g(x) = x^2 - 1[/tex]​
    So, thinking about the chain rule, what would the derivative with respect to x be of [tex]f(x^2 - 1)[/tex]?
  7. Dec 6, 2007 #6
    Yes, the correct answer is [tex]f'(x^2-1)(2x)[/tex].
  8. Dec 6, 2007 #7
    so new solution is:
  9. Dec 6, 2007 #8
    Yup. That's right.
  10. Dec 6, 2007 #9
    great. thanks a lot man. really starting to understand.
    another problem. i have soloved it, but need to see if i have done it correctly.
    Q-skydiver jumps from plane at 3000m. distance fallen in meters after t seconds is:
    [tex] s=5t^2[/tex]
    During fall, experiences air pressure [tex]p[/tex] that will cause his ears to pop if the rate of change of pressure [tex]\frac{dp}{dt}[/tex] exceeds 2 pressure units/s. suppose that the rate of change of pressure with respect to distance fallen in metres is 0.075 pressure units/m. what time will the sky divers ears pop? At what height will this occur?
    Solution attempt:
    A)time ears pop
    [tex]\frac{ds}{dt}= 10t[/tex]
    b)height of poping
  11. Dec 6, 2007 #10
    Yes, that looks right too.
  12. Dec 6, 2007 #11
    cool. that's 2 out of 4 on the worksheet. onto number three.
    suppose that f and g are functions such that:
    [tex]f(1)=-\frac{1}{2}[/tex] , [tex]f'(1)=-\frac{2}{3}[/tex] , [tex]g(2)=1[/tex] and [tex]g'(2)=3[/tex]
    find [tex]h'(2)[/tex] where [tex]h[/tex] is the composite fuction [tex]h(x)=f(g(x))[/tex].
    so in this to get [tex]h'(2)[/tex] i need to just take the derivative [tex]f'(1)[/tex] and multiply it by the derivative [tex]g'(2)[/tex] ?
    [tex]-\frac{2}{3} * 3 [/tex].
    so [tex]h'(2)[/tex] is equal to -2?
    it seems wrong to me because i have done it too simply. did i completely miss the mark? or partialy?
  13. Dec 6, 2007 #12
    I think you understand the chain rule, so you should have a good idea whether that is correct or not.
