Solving Derivative of Natural Logarithm of Negative x
In summary, Mark is asking how to find the last derivative of an equation, and he has been told by Jazznaz that the last derivative is -x-1. However, Jazznaz also tells Mark that it might be helpful to replace x with u in what he has written, which leads to a different last expression -\frac{d ln(u)}{du}.
Niles
1,866
Hi.
I want to solve:
[tex]
\frac{d\ln(-x)}{dx}.
[/tex]
When using the chain rule I get:
[tex]
\frac{d \ln(-x)}{dx} = \frac{d\ln(-x)}{d(-x)}\frac{d(-x)}{dx} = -\frac{d\ln(-x)}{d(-x)}.
[/tex]
But how do I find the last derivative? I know by experience that it is -x-1, but how is the derivation done?
Thanks in advance.
The last derivate is of the same form as:
[tex]\frac{d}{dx}\ln x[/tex]
Which is a simple solution, no?
The last derivative works out to - 1/(-x) = 1/x, not -x^(-1) as you have.
For the same reason that [itex]\int dx/x = ln |x| + C[/itex], d/dx(ln |x|) = 1/x.
This means that d/dx(ln(x)) = d/dx(ln(-x)) = 1/x.
If this is true, then we obtain a total of -1/x. And jazznaz is telling me the opposite of you?
Thanks for replying.
Niles said:
If this is true, then we obtain a total of -1/x. And jazznaz is telling me the opposite of [Mark]?
Well, no, but it probably helps to replace x with u in what Jazznaz wrote.
[tex]
[/tex]
To derive
[tex]\frac{d}{du} \ln{u} = \frac{1}{u}[/tex]
first let [tex]y = \ln{u}[/tex]. Then [tex]e^y = u[/tex]. Now use implicit differentiation to find [tex]\frac{dy}{du}[/tex] (which is [tex]\frac{d}{du} \ln{u}[/tex] ) in terms of u.
Niles said:
Hi.
I want to solve:
[tex]
[/tex]
[tex]
[/tex]
Thanks in advance.
If you let u= -x, your last expresion is [tex]-\frac{d ln(u)}{du}[/tex]. Does that make more sense?
Yes, that does make sense.
I understand it now. Thanks to everybody for helping.
What is the derivative of ln(-x)?
The derivative of ln(-x) is equal to -1/x.
Can the derivative of ln(-x) be simplified?
Yes, the derivative of ln(-x) can be simplified to -1/x.
Is the derivative of ln(-x) defined for all values of x?
No, the derivative of ln(-x) is only defined for negative values of x. For positive values of x, the derivative is undefined.
What is the domain of the derivative of ln(-x)?
The domain of the derivative of ln(-x) is all negative real numbers.
Can the derivative of ln(-x) be used to solve real-world problems?
Yes, the derivative of ln(-x) is often used in physics and engineering to find rates of change and solve optimization problems.
