Homework Help: Chain rule
  1. Mar 16, 2014 #1
    Differentiate the following by rule y=(2x2+4x)5
    Is the chain rule the right rule to use?
    dy/dx=dy/du*du/dx
    Let U=2x2+4x
    du/dx=4x+4
    y=(u)5 → dy/du=5(u)4
    dy/dx=5(u)4*4x+4
    dy/dx=5(2x2+4x)4*4x+4
    dy/dx= 30(2x2+4x)44x
    dy/dx= 30(2x216x)4
    I'm wondering if I am on the right track?
  3. Mar 16, 2014 #2
    Mark44
    Staff: Mentor
    Anthonyk, your questions should be posted in the Homework & Coursework sections (Calculus & Beyond) - not in the technical math sections.
  4. Mar 16, 2014 #3
    ok no problem
  5. Mar 16, 2014 #4
    Ray Vickson
    I hope you did not mean what you wrote, which was
    [tex] \frac{dy}{dx} = 5(x^2 + 4x)^4 4x + 4, \text{ which } = 4 +5(x^2 + 4x)^4 4x [/tex]
    I hope you meant
    [tex]\frac{dy}{dx} = 5(x^2 + 4x)^4 (4x + 4) [/tex]
    If that is what you did mean, that is what you should write; note the parentheses.
  6. Mar 16, 2014 #5
    Mark44
    Staff: Mentor
    Use parentheses where they are needed.
    The right side should be 5u4 * (4x + 4)
    That last factor should be (4x + 4)
    No. I can't tell what you did here. How did you get 30 at the beginning of the right side?
  7. Mar 16, 2014 #6
    vela
    Staff Emeritus
    Education Advisor
    In addition to what Ray noted, I can't figure out what you did to get the last two lines. You need to go back and review algebra.
  8. Mar 16, 2014 #7
    Ya sorry that is what I meant.
    can I simplify this further or can I leave it like that?
  9. Mar 16, 2014 #8
    Mark44
    Staff: Mentor
    You can factor 4 out of the 4x + 4 term, and put it with the 5 factor. Otherwise, that's about all you can do. For most purposes, leaving it in factored form is preferable to multiplying everything out.
  10. Mar 16, 2014 #9
    dy/dx=20(2x2+4x)*(4x) this what you mean
  11. Mar 16, 2014 #10
    Mark44
    Staff: Mentor
    No. Like vela said, you need to take some time to review algebra.
    Starting from here:
    dy/dx=5(2x2+4x)4 * (4x+4), factor 4 out of the last expression in parentheses, and combine that 4 with the leading 5. You did this, but the problem is that 4x + 4 ≠ 4*x. That seems to be what you're doing.
  12. Mar 17, 2014 #11
    dy/dx=5+4(2x2+4x)44x
    dy/dx=9(2x2+4x)44x
    or
    dy/dx=10x2+20x*(4x+4)
  13. Mar 17, 2014 #12
    BruceW
    none of those. take your time, just using rules of arithmetic that you are certain about. for example, (4x+4) = 4*(x+1) right? So then what does the equation look like?
  14. Mar 17, 2014 #13
    I know this is probably very simple I just cant get it.
    dy/dx=5(2x2+4x)*(4x+4)
    Do I separate it out and treat 5(2x2+4x) from (4x+4)
    5(2x2+4x)*4(x+1)?
  15. Mar 17, 2014 #14
    BruceW
    yeah, almost. you forgot the first bit should be to the power of four. so it is 5(2x2+4x)4*4(x+1) And yes, it is fine to 'separate out'. In arithmetic, it is always OK to say a*(b*c)=a*b*c i.e. in this case 5(2x2+4x)4*(4x+4) = 5(2x2+4x)4*4(x+1)
  16. Mar 17, 2014 #15
    5(2x2+4x)4*4(x+1)
    Thanks very much, frustrating that its so simple. thanks again
  17. Mar 17, 2014 #16
    BruceW
    glad to have helped! yeah, I'm writing Makefiles at the moment, which should be a simple programming thing to do. But it's taking me ages! haha
  18. Mar 17, 2014 #17
    Best of luck.
  19. Mar 17, 2014 #18
    You are really not going to be able to do calculus unless you have good facility with algebra. You did not realize that you could combine the factors 5 and 4 to give 20. Your previous posts had several algebra errors in them. I implore you to please follow Vela's advice and review algebra.
    Chet
  20. Mar 17, 2014 #19
    Thanks I have been looking over it today. It's just the work load of study, job and kids I can only do so much.
    I can multiply 5*4 to get 20. Can I do anything with what in the bracket?
  21. Mar 17, 2014 #20
    Yes, you can factor out a 2, and, when it comes out of the bracket, it becomes 24=16, which, when multiplied by the 20 becomes 320.
    Chet
  22. Mar 17, 2014 #21
    vela
    Staff Emeritus
    Education Advisor
    You'll be much more efficient at studying once you get the algebra down. You don't want to be wasting time struggling with algebra instead of concentrating on the material you're supposed to be learning. I'll note that with this problem, you had the calculus part — applying the chain rule — done correctly; it was only the subsequent algebra that was a problem. It might feel like reviewing algebra is a low priority, but you really should make it a higher one.
  23. Mar 17, 2014 #22
    Mark44
    Staff: Mentor
    I agree with what vela and Chet have said. I recognize that you have a lot of time constraints at the moment, with kids, job, and school, but a small amount of time spent at bolstering your algebra skills (say, 30 minutes of focused effort a day) will save a lot of time down the road.
  24. Mar 17, 2014 #23
    I will try and put some time aside for algebra, thanks for advice and help I appreciate it. Cheers and happy st Patrick's day :-)
Have something to add?
Draft saved Draft deleted
Loading...
