- 5,587
- 1,515
Prove that
[tex] \sum_{k=0}^{n} \sin\left( \frac{k \pi}{n} \right) = \cot \left( \frac{\pi}{2n} \right) [/tex]
CosmicKitten said:I stumbled upon a really complicated way to d0 it by induction... too tired now to do the arithmetic and see if it works right now. After easily establishing that both sides equal 0 for n=1, it involves turning the right side into the form (e^ipi/n + 1)/(e^ipi/n -1) and multiplying the numerator and the denominator by e to the power of (i*pi/n^2)/(1+1/n) which turns the denominator of the exponent into n+1 without changing the numerator, but it changes the 1 on the numerator and the -1 in the denominator so you must add something to make them turn back into 1 and -1 without changing the e^ipi/n+1's. So add A/B to that and solve for A and B and then add A/B to the other side and see if you can get it in the n+1 form. Is that on the right track?
chingel said:Since on an x-y plane the sine is the vertical projection of a segment of length 1 at a particular angle and we are trying to find the sum of sines, that is the sum of the vertical projections, we can add up all the segments and then find the vertical projection of the sum. Noticing that the angles increase with regular intervals and that the segments make up half of an 2n-gon, then the vertical projection of the sum is just twice the apothem of the 2n-gon and using the well known simple formula for the apothem we get the answer.
http://www.buzzle.com/articles/finding-apothem-of-a-regular-polygon.html
Challenge 13: Sums of Sines is a mathematical challenge that involves finding the sum of several sine functions, with each function having a different amplitude, frequency, and phase shift.
The purpose of this challenge is to test one's understanding of sine functions, as well as their ability to manipulate and combine multiple functions.
To solve this challenge, one should have a solid understanding of trigonometric functions, specifically sine functions, as well as knowledge of amplitude, frequency, and phase shift.
The most efficient approach to solving this challenge would be to use mathematical identities and properties of sine functions to simplify the sum before calculating the final answer.
While this challenge is primarily a mathematical exercise, the concept of combining multiple sine functions can be applied in fields such as engineering, physics, and signal processing.
