Change in Angular Momentum Calculation
In summary, the question involves a steel disk with a diameter of 400mm and a mass of 48.98 kg accelerating from 6.28rad/s to 43.98rad/s. The change in angular momentum is calculated using the formula I = mr^2/2, where I is the moment of inertia, m is the mass, and r is the radius. The change in angular momentum is found to be 147.70 kgm^2/s. The change in angular kinetic energy is calculated using the formula 1/2I(w2^2-w1^2), which results in 1.39 kJ.
series111
54
a steel disk 400mm in diameter and a mass of 48.98 kg accelerates from 6.28rad/s to 43.98rad/s calculate the change in angular momentum.
final angular momentum = intial momentum
(I) final x (w) final = (i) initial x (w) intial
I= mr _2
(I) initial = 48.98 x 200x10^-3_2 = 1.95 kgm_2/s
(I) final = (I) initial x (w) initial/ (w) final = 1.95 x 6.28/ 43.98 = 0.278 kg/m_2
change in angular momentum = final - initial
(I) initial x (w) initial - (I) final - (w) final
= 1.95 x 6.28 - 0.278 x 43.98 = 19.56 x 10 -3 kgm_2/s
can someone check if this correct thanks again...
You calculate a change in angular momentum in part 3 after assuming the angular momentum is constant in part 2.
The angular momentum is I * ω, and since the moment of inertia I is constant, the change in angular momentum is I * Δω, where
( http://en.wikipedia.org/wiki/List_of_moments_of_inertia )
I = m * r^2 / 2 = 48.98 kg * ( 0.4 m / 2 )^2 / 2
and
Δω = ( 43.98 - 6.28 ) rad/s.
so I = 3.918kgm_2/s and Δω = 37.7 rad/s
and the change in angular momentum is = I * Δω = 3.918 x 37.7 = 147.70 kgm_2/s
thanx for putting me right...
and
This is wrong, from the handout I have the Angular Momentum = Iw(omega)
There is no division of 2. Wikipedia though helpful, isn't the best source of evidence to use because anyone can edit it.
Where did you get 3.918 kgm^2/s from calculating this:
I'd like to ask for help since I have the exact same question to do.
Using the same values I got this below:
I = mr^2 = 48.984 x (0.2)^2 = 1.95936 = 1.96 kgm^2/s
w2 - w1 = 43.98 - 6.28 = 37.7 rad/s^2
therefore: 1.96 x 37.7 = 73.892 kgm^2/s
The next question asks for the change in angular kinetic energy.
This is what I got:
Equation - Angular ke = 1/2Iw^2
1/2x(1.96 x (37.7)^2) = 1.39x10^3
Angular ke = 1.39 kJ
Is this correct??
The 1/2 is for the moment of inertia of a solid disk about its center perpendicular to the plane of the disk, not angular momentum. I used Wikipedia because it's a known result, and I didn't want to do this:
\begin{equation} I = \int dm \ r^2 = \int \left(\frac{M}{\pi R^2} r d\theta dr\right) r^2 = \frac{M}{\pi R^2} \int_0^{2 \pi} d\theta \int_0^R dr r^3 = \frac{1}{2} M R^2 \end{equation}
Yes my calculations were wrong however I did calculate them again and got the write answers through a little research :
K^2 = d^2/8 ( This is for a soild Disk i.e Steel Disk)
Where I=mk^2
Where Iw2 - Iw1 ( change in angular momentum)
As for change in angular kinetic energy you are using the correct formula just wrong values.
@EricAngle - appolagies haha.
@series111 - I've actually figured it all out now.
My method is wrong because above I do this: (w2-w1)^2
But the correct method is (w2^2-w1^2)
Therefore: 1/2 I (w2^2-w1^2).
But glad you replied. Cheers.
1. What is angular momentum?
Angular momentum is a measure of an object's rotational motion. It is the product of an object's moment of inertia and its angular velocity, and is typically represented by the symbol L.
2. How does angular momentum change?
Angular momentum can change due to external forces acting on an object, such as torque, or changes in the object's moment of inertia or angular velocity. This change is known as the change in angular momentum.
3. What is conservation of angular momentum?
Conservation of angular momentum states that in a closed system, the total angular momentum remains constant. This means that if there are no external torques acting on the system, the initial angular momentum will be equal to the final angular momentum.
4. What is the equation for change in angular momentum?
The equation for change in angular momentum is given by ΔL = τΔt, where ΔL is the change in angular momentum, τ is the applied torque, and Δt is the time interval over which the torque is applied.
5. How does change in angular momentum relate to rotational motion?
Change in angular momentum is directly related to the rotational motion of an object. As the moment of inertia or angular velocity changes, the angular momentum will also change. This change in angular momentum can affect the object's rotational motion, causing it to accelerate or decelerate.
