Calculate Velocity of Gliders After Collision: -1m/s Left
In summary: I think I understand what's going on now.In summary, a conversation about calculating the velocity and direction of two gliders after a collision was summarized. The conversation also touched upon the equations for conservation of momentum and the difference between inelastic collisions and explosions. The final answer for the velocity of the gliders after the collision was determined to be 0.6m/s in the direction of the initial collision.
MrPickle
56
There are two 'gliders' X and Y on an air track. The mass of X is 0.2kg and it's velocity is 1.5m/s to the right. The mass of Y is 0.3kg and it is stationary. When 'glider' X collides with trolley Y they move off together.
Calculate the velocity of the 'gliders' after the collision and give their direction.
mass x velocity = momentum
mass Y x velocity Y = -(mass X x velocity X)
0.3 x velocity Y = -(0.2 x 1.5)
[tex]Velocity Y = \frac{-0.3kgm/s}{0.3kg} = -1[/tex]
So it's moving 1m/s to the left? I'm not sure whether that's the velocity of both of the gliders, or just velocity of Y because that's what my equation shows.
This is incorrect. What would be true is that the change in Y's momentum will be equal and opposite to the change in X's momentum.
Treat this as a completely inelastic collision (the carts stick together and thus end up with the same final velocity) and write an equation for momentum conservation.
My book says that's the equation for conservation of momentum.
What book are you using?
I suspect that the equation in your book is more like:
[tex]M_y \Delta V_y = - M_x \Delta V_x[/tex]
For inelastic collisions, I recommend this version:
[tex]m_1v_1 + m_2v_2 = (m_1 + m_2)v_f[/tex]
My book is AQA Science GCSE Physics
Conservation of momentum in an explosion
In the trolley examples:
  • momentum of A after the explosion = (mass of A x velocity of A)
  • momentum of B after the explosion = (mass of B x velocity of B)
  • total momentum before the explosion = 0 (because both trolleys were at rest).
Using conservation of momentum gives:
(mass of A x velocity of A) + (mass of B x velocity of B) = 0
Therefore
(mass of A x velocity of A) = -(mass of B x velocity of B)
This tells us that A and B move apart with equal and opposite amounts of momentum.
You have to learn to distinguish an equation that is generally valid (such as conservation of momentum when there is no external force), and equations that apply to specific situations (such as the one you are using, even though that equation follows from the more general law).
There is no other equations to do with conservation of energy in my book though :(
I hate my stupid Physics/Chemistry teachers, he teaches us jack all. He told us out loud he's not going to teach us the theory. WTF is he going to teach us then.
Wow, that's sad...I suppose he is "teaching" you how to mindlessly put numbers into equations.
In any case, the general equation for conservation of momentum (assuming the masses stay constant!) is that:
[tex]
\sum_i m_i \vec{v}_i^{{\rm b}} = \sum_i m_i \vec{v}_i^{{\rm a}}
[/itex]
thus relating velocities before (b) and after (a) a collision between particles with masses m_i.
I thought mass was constant O.O
What's that big E thing mean?
I was just having troubles with LaTeX: it's fine now. There's no big E anymore.
It's still there, this thing: [tex]\sum[/tex]
Oh, that's a summation sign: you sum over all particles in your system. In your case you have two gliders, X and Y, so you'd sum over i taking the values X and Y.
Written in a different way, you have:
[tex]
m_X v_X^b+m_Yv_Y^b=m_X v_X^a+m_Yv_Y^a
[/tex]
Now that, I understand apart from the ^a and ^b, where has a and b come from or is that what I need to work out?
a=after
b=before
So:
[tex]0.2\times1.5 + 0.3\times0 = (m_Xv_X + m_Yv_Y)^a[/tex]
[tex]\frac{0.3}{1.5 + 0.3} = (v_X + v_Y)^a[/tex]
and that gets me the final velocity?
Not quite, but you're on the right track:
first you should note that after the collision X and Y end up traveling with the same velocity, so v_X^a=v_Y^a.
Second, I don't know why you divided by 1.5+0.3: the masses are 0.2 and 0.3, not 1.5 and 0.3!
Don't forget that after the collision the trolleys "move off together"--that means they have a single velocity after the collision.
It might be simpler for you to use the equation I gave in post #4. (The 2nd equation. The left side represents the momentum before the collision; the right side, after the collsion.)
I think I've got it now:
[tex]Velocity = \frac{0.3}{0.5}[/tex]
So the velocity is 0.15m/s to the left?
Good.
No. (That fraction doesn't equal this.)
to the left?
Why to the left?
Oops, 0.18m/s I must of hit * on the calculator instead of /
and I think it might be to the right because that's the direction in which glider X hits glider Y and they'll carry on moving together.
Still not right. Do it one more time.
Much better.
Ahhh, 0.6m/s
3rd time lucky?
MrPickle said:
Ahhh, 0.6m/s
3rd time lucky?
Good. 3rd time's the charm.
I recommend that you review the entire calculation to make sure you understand everything covered in this thread.
(I find it hard to believe that your book covers momentum conservation for explosions, but not collisions. Better double check that. :wink:
Of course, an inelastic collision can be considered the mirror image of an explosion.)
Could you give me an example question or point me to a site which can provide me with several samples please?
Thanks for the help BTW.
1. How do you calculate the velocity of gliders after a collision?
To calculate the velocity of gliders after a collision, you need to use the conservation of momentum principle. This means that the total momentum before the collision is equal to the total momentum after the collision. You also need to take into consideration the masses and velocities of the gliders before the collision.
2. What is the formula for calculating velocity after a collision?
The formula for calculating velocity after a collision is: v = (m1v1 + m2v2) / (m1 + m2), where v is the final velocity, m1 and v1 are the mass and velocity of the first glider, and m2 and v2 are the mass and velocity of the second glider.
3. Do you need to know the direction of the gliders' velocities to calculate their final velocity?
Yes, you need to know the direction of the gliders' velocities to calculate their final velocity. This is because the velocities are vectors and their direction affects the final velocity after the collision.
4. What is the unit of measurement for velocity?
The unit of measurement for velocity is meters per second (m/s). This is the standard unit for measuring the speed of an object.
5. What does a negative velocity indicate in this scenario?
In this scenario, a negative velocity of -1m/s left indicates that the gliders are moving in opposite directions after the collision. The negative sign indicates the direction of the velocity, in this case, to the left.
