Change in Pressure
An experiment to determine the specific heat of a gas makes use of a water manometer attached to a flask (the figure below ). Initially the two columns of water are even. Atmospheric pressure is 1.5 105 Pa. After heating the gas, the water levels change to those shown. Find the change in pressure of the gas in Pa.
2. Homework Equations
[tex]\Delta[/tex]P = [tex]\rho[/tex]g[tex]\Delta[/tex]h
I basically did 1.5 x 10 ^5 * 9.8 m/s2 * .01m (what I assume given the picture to be the change in height)
Answers and Replies
rl.bhat
4,433
Difference in water level is 4 cm.
So ΔP = ρgΔh.
If I change 4 cm to meters I get 58800 as the calculated total from the equation, which is incorrect according to the website. Is there some factor I'm neglecting?
cepheid
Staff Emeritus
38
Rho is the density of the fluid, not the pressure, so I'm not sure why you are using 1.5e5 in the equation. Also, pay attention to units when you are doing your computation (doing so would have revealed this error).
Related Threads on Change in Pressure
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
