Calculating Change in Length for a Steel Bridge Span Without Expansion Joints
In summary, the change in length of the main span of the Golden Gate Bridge without expansion joints would be 0.286 meters for an increase in temperature of 20°C.
dymand68
Suppose the 1.3 km main span of steel for the Golden Gate Bridge had no expansion joints. How much longer would it be for an increase in temperature of 20°C?
change in Length=Length*coefficient linear expansion*change in temp.
=1300*(11*10^-6/20)*20
incorrect:
.0143 meters
.2625
.1575
correct answer =.286 meters
incorrect:
.0143 meters
.2625
.1575
your formula is correct, so why did you divide by 20??
1. What is a change in span length?
A change in span length refers to any adjustment made to the distance between two fixed points or supports in a structure, such as a bridge or building. This can involve increasing or decreasing the length of the span, which can impact the overall stability and strength of the structure.
2. What factors can cause a change in span length?
There are several factors that can contribute to a change in span length, including environmental conditions such as temperature fluctuations or natural disasters, changes in the weight or load on the structure, or structural damage due to wear and tear.
3. How does a change in span length affect the structural integrity of a building?
A change in span length can significantly impact the structural integrity of a building by altering the distribution of forces and loads within the structure. This can lead to increased stress or strain on certain components, potentially causing structural failure if not addressed properly.
4. Can a change in span length be prevented?
In some cases, a change in span length can be prevented by implementing proper design and construction techniques, using high-quality materials, and regularly maintaining and inspecting the structure. However, certain factors, such as natural disasters, may be beyond our control.
5. How is a change in span length measured and monitored?
A change in span length can be measured and monitored using various techniques, including strain gauges, displacement sensors, and laser scanning. These tools can accurately measure any changes in the length of the span and help engineers determine the best course of action to address them.
11K
9K
