Homework Help: Change in Velocity
  1. Jan 26, 2009 #1
    I am required to find the change in velocity given these two vectors:
    Va = 4.4 m/s [E31*S]
    Vb = 7.8 m/s [E25*N]
    2. Relevant equations
    delta V = Vb - Va
    delta V = Vb + (-Va)
    3. The attempt at a solution
    I am stuck between two solutions:
    #1. Simply subtracting the vectors:
    V = Vb - Va
    V = (7.8, 25*) - (4.4, 31*)
    V = [7.1, 3.3] - [3.8, 2.3]
    V = [3.3, 1.0]
    V = (3.5, 16.8*)
    #2. Reversing the direction of Va, its directionality becomes [W31*N], effectively 149*.
    V = Vb + (-Va)
    V = (7.8, 25*) + (4.4, 149*)
    V = [7.1, 3.3] + [-3.8, 2.3]
    V = (6.5, 59*)
    Which solution is correct and why? The first would solution would be the same if you distributed -1 across to both terms, but I'm pretty sure that operation is not permitted.
  3. Jan 26, 2009 #2
    LowlyPion
    Doesn't taking the negative vector mean that the -31 is really 149 + 180 = 329
  4. Jan 26, 2009 #3
    I don't think so, as can be seen here:
    http://i543.photobucket.com/albums/gg464/yowatupguystill/vector-1.jpg [Broken]
    EDIT: I might have been correct on my first attempt, but I had assumed that this was correct: https://www.physicsforums.com/archive/index.php/t-275728.html
  5. Jan 26, 2009 #4
    LowlyPion
    What is shown in your drawing is 329° and you are reversing it to 149° .
  6. Jan 26, 2009 #5
    Yes. Is that not correct, given that we are reversing the direction?
    Secondly, I have just drawn out a vector diagram to scale of the vectors in question. It seems to support #2, though I'm not sure how certain to be - given that I haven't work graphically with vectors in a while.
  7. Jan 26, 2009 #6
    LowlyPion
    I believe Method 2 is the right way - the sum of the vector and the negative of a vector to do a vector subtraction..
