Homework Help: Change of base calculations
  1. Dec 5, 2013 #1
    1. Convert (0.333...)4to base 10.
    2. Convert (0.333...)10to base 4.
    2. Relevant equations
    For question 1:
    I see this can be written as (3/4+3/42+3/43...)10
    Can I just use the geometric formula and arrive at the answer 12/3=4 ?
    But that doesn't match, because 4 in base 10, written in base 4 is just 10.
    For problem 2 I'm not sure how to start. There was a trick regarding division and keeping the remainder, but I'm not sure that applies to decimals.
    3. The attempt at a solution
  3. Dec 5, 2013 #2
    tiny-tim
    hi srfriggen! :smile:
    yes, but doesn't your formula apply to 1 + 3/4 + … ? :wink:
    (btw, doesn't that look a lot to you like 0.9999… ?)
    you mean to quaternary? (quaternals?)
    yes, long division works in any system :smile:
  4. Dec 5, 2013 #3
    the series can be written as 3*10-1+3*10-2+3*10-3...
    And isn't the formula for a geometric series: a(1/1-r)?
    So here, a=3 and r=1/4, right?
    When I plug in and multiply out I get an answer or 4, not .9...
    What am I missing?
  5. Dec 5, 2013 #4
    tiny-tim
    3*1 + 3*10-1+3*10-2+3*10-3...= a(1/1-r) :wink:
  6. Dec 5, 2013 #5
    Wait, I wrote that out wrong, it's not:
    those 10s should be replaced with 4s, right?
    I'm still getting a=3 and r=1/4. Am I right with that?
  7. Dec 5, 2013 #6
    tiny-tim
    a*(1 + b + b2 + b3) + … = a/(1 - b)
    you left out the a*1 (= 3), which if you subtract from 4 is …? :wink:
  8. Dec 5, 2013 #7
    so isn't the formula a=3 and b=1/4? If so that still give the answer or 4. I don't see where subtracting 3 comes into play.
  9. Dec 5, 2013 #8
    tiny-tim
    your formula does not have an a*1 …
    it starts with a*b :smile:
  10. Dec 5, 2013 #9
    I'm looking at my book now and it says the formula is a(1/1-r). If a=3 and r=1/4, I get the answer to 4. I'm not sure what is wrong of the previous statement? Either my formula is wrong or my a and r choices are wrong.
  11. Dec 5, 2013 #10
    I'm sorry tiny tim I'm just not getting it today. I'm gonna take a break, so some studying later, and come back to this one. Thanks for your patience so far!
  12. Dec 5, 2013 #11
    tiny-tim
    a*(1 + b + b2 + b3 + …) = a/(1 - b) = 3/(1 - 1/4) = 4
    a*(b + b2 + b3 + …) = a/(1 - b) - a = ab/(1 - b) = 4 - 3 = 1
  13. Dec 5, 2013 #12
    ahhh, now I see what you meant by "your formula" !
  14. Dec 5, 2013 #13
    tiny-tim
    ok, alternative method: can you see that 0.33333 = 1 - 0.00000… ?
    (ie you can't get any closer to 1 ! :wink:)
Have something to add?
Draft saved Draft deleted
