1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Change of variable
  1. Dec 11, 2012 #1
    Let x,y be iid and [tex]x, y \sim U(0,1) [/tex] (uniform on the open set (0,1)) and let [tex] z = xy^2. [/tex]
    Find the density of z.
    2. Relevant equations
    3. The attempt at a solution
    [itex]P(z \leq w) = P(xy^2 \leq w) = P(- \sqrt{\frac{w}{x}} \leq y \leq \sqrt{\frac{w}{x}}) = \int^{ \sqrt{\frac{w}{x}}}_{ -\sqrt{\frac{w}{x}}} dy = 2 \sqrt{\frac{w}{x}}
    Is this right. Seems like I am missing something, not sure.
  3. Dec 11, 2012 #2
    Ray Vickson
    No. Y cannot be < 0, so you cannot have the region ## - \sqrt{w/x} \leq y < 0##. Anyway, you need an answer that contains w only, so you still need to get rid of the 'x'.
  4. Dec 11, 2012 #3
    [itex]P(z \leq w)[/itex] should be a function of w only, so something's wrong.
    Fix x. Then [itex]P(y^2 \leq w/x) = P(0 \leq y \leq \sqrt{w/x}) = \min(1,\sqrt{w/x})[/itex] since [itex]0 \leq y \leq 1[/itex]. Then
    P(z \leq w) = P(xy^2 \leq w) = \int_0^1 \min\left(1,\sqrt{\frac wx}\right)\,\mathrm{d}x
    = \int_0^w 1\,\mathrm{d}x + \int_w^1 \sqrt{\frac wx}\,\mathrm{d}x
  5. Dec 11, 2012 #4
    Makes sense it should be a function of w only. I do not understand though how the integral with the minimum is broken up into the two integrals at the end. Any insight?
    Thanks for the help.
  6. Dec 11, 2012 #5
    Ray Vickson
    Look at the two cases x > w and x < w.
  7. Dec 11, 2012 #6
    The first integral ranges from ##x=0## to ##x=w##, so the minimum is equal to 1. In the second integral, you have ##x\geq w##, and so the minimum is the square-root expression.
