Changing order of integration
In summary, Switching the order of integration results in a different region of integration that uses horizontal strips.
says
594
Switch the order of integration:
∫∫f(x,y) dydx, with 0≤x≤π/2, 0≤y≤sin(x)
∫∫f(x,y) dxdy, with sin(x)≤x≤π/2, 0≤y≤sin(x)
The upper bound of x is π/2, while the lower bound is sin(x). It's just the first 1/4 of the area of a sine wave. The upper bound of y is sin(x) and lower bound is 0.
I was just wondering if someone could confirm. I've been having a bit of trouble with integrals and assigning regions. Thank you :)
No. In the first integral above, you are looking at vertical strips that go from y = 0 to y = sin(x), and summing them as x ranges from x = 0 to x = pi/2.
No. Switching the order of integration means that you will now be using horizontal strips, and summing them from bottom to top.
What is the leftmost x-value on a given horizontal strip? (The rightmost x-value is pi/2.)
You need to be thinking about inverse functions.
The rightmost value is pi/2, so the leftmost value would be sin(x), no?
Or should I be saying the leftmost value is 0?
I'm saying sin(x) because when we sub in sin(0) we get 0.
Think of a little dydx square in the middle of your area. Now move it left and right. Your inner integral should look like ##\iint_{x_{left}}^{x_{right}}f(x,y)~dxdy##. When you move that dydx square to the left it hits the sine curve. What is the x value there in terms of y? The value sin(x) you suggested in post #3 is the y value, not the x value.
Have you drawn a sketch of the region over which integration is being performed? If not, you really should.
Also, instead of saying "leftmost value," it's better to specify leftmost x value, as well as lower y value and upper y value.
I drew a picture. Always the first thing I do.
The leftmost x value, judging by my picture, = 0, while the rightmost value = pi/2
The upper y value = sin(x) while the lower y value = 0
0≤x≤pi/2
0≤y≤sin(x)
For the shaded region, is the leftmost x value 0 for each point on the left edge of the region?
0≤x≤pi/2
0≤y≤sin(x)
Look at what LCKurtz wrote a few posts back.
opps, please refer to post #7 :)
0≤x≤pi/2
0≤y≤sin(x)
Which makes me think you haven't read my post #5.
Oh, so I want the leftmost value for the whole region. I was just writing down 0 because 0 is the leftmost point!
The leftmost x=sin(x) and the rightmost pi/2
the upper y = sin(x) and lower = 0
How is this different from my original answer though?
sin(x)≤x≤pi/2
0≤y≤sin(x)
The two inequalities should really be 0 ≤ y ≤ sin(x), 0 ≤ x ≤ π/2
In the original integral, you are using vertical strips, each of which ranges from y = 0 to y = sin(x). The outer integral sums all of these vertical strip areas, as x ranges between 0 and π/2.
Switching the order of integration means you need a different description of the region. In this integral, the inner integral uses horizontal strips, each of which ranges from x = ##x_{left}## to x = ##x_{right}##. The horizontal strip areas are then summed as y ranges from 0 to 1.
You need to figure out what ##x_{left}## and ##x_{right}## are. I'm pretty much repeating what I said in post #2.
Note: I've been a little sloppy by saying "area" above. Since the integrand contains a function, you aren't actually computing the area.
x = sin(x) makes no sense here.
For the equation y = sin(x), if you know an x value, it's easy to get the y value. However, what if you know the y value? How do you get the x value on the same graph?
sin(x)≤x≤pi/2
0≤y≤sin(x)
It's not different -- that's the problem, since your first answer was wrong.
if x=0 then sin(0) = 0, so how come sin(x)≤x≤pi/2 can't be a valid region also?
I don't understand what you mean by saying x = sin(x) makes no sense?
Ignore that last question! I understand now. Thanks :)
So what is your answer to the problem?
∫∫f(x,y) dxdy, with 0 ≤ x ≤ π/2, 0 ≤ y ≤ sin(x) being the lower and upper bounds of integration.
No. All you really have done is switch dx and dy in the integral, and swap the order of the inequalities. Go back and read the replies in posts 2, 5, 10, 12, 15, and 16.
It's just that one lower bound x value I'm confused with.
arcsin?
He's all yours Mark44. I have something I have to do the next few hours.
I said in an earlier post that the leftmost x was sin(x), to which you said that made no sense, which i understand. You also mentioned inverse functions.
∫∫f(x,y) dxdy, with arcsin ≤ x ≤ π/2, 0 ≤ y ≤ sin(x)
arcsin all by itself isn't a number, but you're on the right track in the first set of inequalities. For the second set, the horizontal strips range from y = 0 to y = ?
Likes says
With all the digital technology on offer, Maths can now more than ever be explored as a discovery science.
You could use wolframalpha to confirm your answer. For example, I've nominated f(x,y) of my choosing and evaluated it between the same boundaries as in your exercise.
http://m.wolframalpha.com/input/?i=integrate+x^2+xy+from+y=0+to+sin(x)+from+x=0+to+Pi/2&x=0&y=0
Then, after working out what you think is the way to perform it with order reversed, give it to wolframalpha to evaluate and see whether this answer agrees with the first.
I tried it, and incorporating arcsin it worked.
∫∫f(x,y) dxdy, with arcsin y ≤ x ≤ π/2, 0 ≤ y ≤ 1
Yes!
Likes says
1. Why do we need to change the order of integration?
The order of integration is typically changed in order to simplify the integration process. In some cases, the original order of integration may result in a more complex integral that is difficult to solve. Changing the order can make the integral easier to solve and can also reveal important relationships between variables.
2. How do we determine the new limits of integration after changing the order?
The new limits of integration are determined by setting up and solving appropriate equations based on the original limits and the new variable relationships. This process may involve using substitution, symmetry, or other mathematical techniques.
3. Can the order of integration be changed for any type of integral?
In general, the order of integration can be changed for any type of integral as long as the new order is valid for the given limits and the integral is convergent. However, some integrals may be more difficult to solve in certain orders, so it may not always be beneficial to change the order.
4. What are some common methods for changing the order of integration?
Some common methods for changing the order of integration include using double integrals, iterated integrals, and polar or spherical coordinates. Other techniques such as trigonometric substitutions, partial fractions, and u-substitution may also be used depending on the integrand.
5. How can changing the order of integration be applied in real-world problems?
Changing the order of integration can be applied in various fields of science and engineering where integration is used to solve problems. For example, in physics, changing the order of integration can help solve problems related to mass, velocity, and acceleration. In economics, it can be used to determine optimal production levels. In general, it can be applied to any problem that involves finding the area under a curve or the volume of a solid.
