Determining Charge Density of Nonconducting Sphere
In summary: E=\frac{1}{4\pi\epsilon_0}\frac{Q}{r^2} and solve for p(r) You find p(r)=-15000 V for the potential at the surface of the sphere.
jackxxny
39
i have:
a nonconducting sphere of radius 25 cm. the electric field points radially away from the center of the sphere, and increase linearly from 0 to 3700V/m at the surface of the sphere.
determine charge density?
i think the E=E0+r*148
so i did [tex]\int E *da = \int p(r) d \tau / \epsilon0 [/tex]
then i substitute E
[tex]da = 4* pi * r^{2}
[/tex]
[tex]
d \tau = 4* pi * r^{2} dr
[/tex]then i simplify for p(r)is that right?
Yes. It is right.
thank you
i got
p(r) = [tex]\epsilon 0 *(E_{}o 2/r +3)[/tex]
can that be?
and now the problem is asking for the potential difference between the center and the surface of the sphere
i know that
[tex]\Delta V = -\int E dr[/tex]
will that do it??
How did you get this one?
Your formula for dV is correct.
[tex]
(Eo+r*148)*( 4* pi * r^{2})* \epsilon 0 = \int p(r) (4*pi*r^{2}) dr
[/tex]
then i take the derivative on both sides and isolate p(r)
i obtain =
[tex]
\epsilon 0*(E0*2/r +396) = p(r)
[/tex]
i got -15000 for the potential. I consider Eo to be zero is that a good assumption?
Is it given in the problem?
no. I thought since the problem said that it is linearly that might work?
No. It is not correct.
Electric field is given.
You have found E = ρ*r/εο. Find ρ.
Now dV = - dE*dr To find the potential V on the surface find the integration.
..."the electric field points radially away from the center of the sphere, and increase linearly from 0 to 3700V/m at the surface of the sphere."
- this means that E=0 at the centre of the sphere and E=Es=3700 V/m at the surface, and increases linearly inside the sphere from r=0 to r=R, the radius of the sphere.
The enclosed charge in the sphere is
[tex]Q=4/3 R^3 \pi \rho [/tex] and by Gauss' Law, [tex] Q=4R^2 \pi \epsilon_0 E_s [/tex]. Comparing the equations for the total charge, you get the charge density.
As for the potential at the surface of the sphere: remember that we usually choose zero potential at infinity, and outside a homogeneously charged sphere the electric field is the same as that of a point charge...
ehild
[tex]
4/3 R^3 \pi \rho = 4R^2 \pi \epsilon_0 E_s
[/tex]
so i just set it equal to each other and solve for p
[tex]
\rho = 3 \epsilon_0 E_s / R
[/tex]
is that it?
Yes. Now calculate it with the given data.
ehild
ok i got the charge density
how do i do the potential
so how do i do this integral
dV = - dE*dr
Previously you have written the integral correctly:
[tex]
[/tex]
You want the potential at the surface of the sphere and you know that it is nought at infinity:
[tex]
\Delta V= V(\infty)-V(R) = -\int_R^\infty{ E dr}
[/tex]
You certainly have learned that the electric field outside a homogeneously charged sphere is the same as if its total charge were concentrated in the centre. What is the field around a point charge?
[tex]
[/tex],
is it right? You know Q, the total charge of the sphere.
Now integrate this formula for E.
ehild
What is charge density?
Charge density refers to the amount of electric charge per unit volume of an object. It is measured in coulombs per cubic meter (C/m^3).
How do you determine the charge density of a nonconducting sphere?
To determine the charge density of a nonconducting sphere, you will need to measure the charge and volume of the sphere. Then, divide the charge by the volume to get the charge density. This can be written as q/V, where q is the charge in coulombs (C) and V is the volume in cubic meters (m^3).
What is the difference between charge density and surface charge density?
Charge density refers to the charge per unit volume of an object, while surface charge density refers to the charge per unit area of an object's surface. Surface charge density is typically used when dealing with flat or two-dimensional surfaces, while charge density is used for three-dimensional objects.
What factors can affect the charge density of a nonconducting sphere?
The charge density of a nonconducting sphere can be affected by factors such as the material of the sphere, the presence of other charges nearby, and the shape and size of the sphere.
Why is determining charge density important in scientific research?
Determining charge density is important in scientific research because it helps us understand the behavior of electric fields and the interactions between charged particles. It is also essential in studying the properties of materials and developing new technologies such as semiconductors and capacitors.
