Homework Help: Charge on a square loop: Work
  1. Nov 11, 2013 #1
    A small bead is on square loop in the xz plane with dimensions (±R, 0, ±R). An electric field is turned that is ##\vec{E}(\vec{r})=-Cx\hat{z}##
    Calculate W
    2. Relevant equations
    ##W= \int q\vec{E}\bullet dl##
    3. The attempt at a solution
    Starting with z direction:
    [tex]q\int_{-R}^R -Cx\hat{z} (dx\hat{x} + dy\hat{y}+ dz\hat{z})[/tex]
    =##-Cq \frac {x^2}{2} |_{-R}^R=-CqR^2##
    I believe that the total work would just be 2 times this quantity because since the E field isn't in the correct direction in order to move the charge in the x direction. But this doesn't make sense to me within the problem context. Am I missing something?
  3. Nov 11, 2013 #2
    tiny-tim
    hi scorpius1782! :smile:
    (type \cdot not \bullet :wink:)
    sorry, but that makes no sense :redface:
    you need to write a dot product
    try again (and use a specific arm of the loop) :smile:
  4. Nov 11, 2013 #3
    thank you for the \cdot! I couldn't remember what it was (kept thinking \vdot) so I gave up and used bullet.
    the vertical (z) part of the box from -R to R at x=-R
    ##\int_{-R}^R-Cqx\hat{z}\cdot dz \hat{z}##
    I didn't think of it before but since here x=-R I can put that in for x in this integral. I believe that since there is no change in x or y then dx and dy are zero.
    This means that ##CqR\int_{-R}^R\hat{z}\hat{z}dz=CqR(R+R)=2CqR^2##
    Then for x=R: ##\int_{R}^{-R}-CqR\hat{z}\cdot dz \hat{z}##
    ##=-CqR\int_{R}^{-R}\hat{z}\hat{z}dz=-CqR(-R-R)=-2CqR^2##
    Is this better?
  5. Nov 11, 2013 #4
    tiny-tim
    yes :smile:
    erm :rolleyes:
  6. Nov 11, 2013 #5
    Hmm, seems I didn't distribute my negative sign there!
  7. Nov 11, 2013 #6
    tiny-tim
    are you in the loop now? o:)
  8. Nov 12, 2013 #7
    I am, thank you. I assume since you made no comment that my understanding of the horizontal forcei is correct? That is where z=±R there is no work?
  9. Nov 12, 2013 #8
    tiny-tim
    yes, for displacement of constant z, the component of the field along the wire is zero, so the work done is zero :smile:
  10. Nov 12, 2013 #9
    Thanks for the help!
Have something to add?
Draft saved Draft deleted
