yjk91
- 75
Two parallel plate capacitors, C1 and C2, are connected in series with a 65-V battery and a 500-kΩ resistor, as shown in the figure. Both capacitors have plates with an area of 2.1 cm2 and a separation of 0.1 mm. Capacitor C1 has air between its plates, and capacitor C2 has the gap filled with porcelain (dielectric constant of 7 and dielectric strength of 5.7 kV/mm). The switch is closed, and a long time passes.
http://www.webassign.net/bauerphys1/26-p-046.gif
(a) What is the charge on capacitor C1?
(b) What is the charge on capacitor C2?
C = E0 * A / d
q = C delta V
C = (8.85 * 10^-12 * 2.1 cm^2 / 10000) ( to change it 2.1 cm^2 to m^2) / 0.0001m)
q = C delta V
= 1.8585e-11 * 65V = 1.21 e -9
the answer is 1.06e-9
where did i go wrong?
i used C = (E0 L^2 / (2d)) (1+k) and it didn't work
any hints?
