Finding the Distance: Charge Particle Motion
In summary, The problem involves a fixed charge and a moving charge with initial conditions of mass, charge, and velocity. The net force on the moving charge can be determined using Newton's 2nd Law, but it is not constant and varies with the distance between the two particles. The distance of closest approach can be found by using conservation of energy and solving for x in the equation \frac{kQq}{0.55 - x} = E_k + \frac{kQq}{0.55}.
flower76
51
Another problem I'm struggling with this one I don't have a clue where to start. Any hints to a starting point would be greatly appreciated.
A charge of -4.00uC is fixed in place. From a horizontal distance of 55.0cm a particle of mass 2.50 x 10^-3 kg and charge -3.00uC is fires with an intial speed of 15.0m/s directly toward the fixed charge. How far does the particle travel before it stops and begins to return back?
The net force on the moving charge should be the force of repulsion it experiences. With this, you can set up an equation using Newton's 2nd Law.
Take note though, that the net force (and hence the acceleration) of the moving particle is not constant, as it varies with the distance between the two particles. Hence, you will need to express acceleration as [tex]\frac{dv}{dt}[/tex], or some other equivalent expression.
Once you have carried out integration, do not forget to add a constant of integration. You can solve for it by using the initial conditions provided in the quesion.
You don't need to integrate. The basic idea is similar to the scattering experiment. The moving charge stops when all its kinetic energy has become zero. A simple energy conservation for the moving charge is to be done here. You need to figure out the distance of closest approach from the static charge.
Pizzasky's approach will land you with the same answer but the basic idea is energy conservation of the moving charge in classical terms.
So here's what I've come up with:
Q = fixed charge
q = moving charge
kQq/(x-0.55m) = kQq/r +(1/2mv^2)
Solving for x.
I'm not sure if x-0.55 is correct? Or even if I've set up the equation correctly?
It's almost right. What's "r"?
r is the initial distance between the charges = 0.55m
You're almost there. Using conservation of energy;
[tex]U_{final} = E_{k} + U_{intial}[/tex]
[tex]\frac{kQq}{0.55 - x} = E_{k} + \frac{kQq}{0.55}[/tex]
~H
Edit: Sorry Doc, guess I was typing for a long time
Right. So, if the moving particle moves a distance x, what's the new separation distance between them?
Hootenanny said:
However, it would be easier to consider the change in distance;
[tex]\frac{kQq}{\Delta r} = E_{k}[/tex]
Since [itex]\Delta r = 0.55 - x[/itex] ;
[tex]\frac{kQq}{0.55 - x} = E_{k}[/tex]
:eek: You might want to reconsider that, Hoot.
I'm not sure, so if
then Ek is the PE + KE of q?
So my equation would be:
[tex]\frac{kQq}{0.55 - x} = \frac{kQq}{0.55} + 1/2mv^2[/tex]?
That's correct.
Wait a minute Doc, I think that I am correct. Why would it be different? The moving particle is doing work against the electrostatic force, therefore kinetic energy will be converted into potential.
~H
So I plugged in the numbers based on my final equation and got 1.05m. So this means that the fired particle goes past the fixed charge before it would turn back, does this make sense?
Just for reference, when using my formula I obtained 16.6cm for the distance of closest approach. I'm not sure whether it is correct though, I am waiting for Doc Al to respond.
~H
Of course this does not make sense. That is one reason why it is important to 'develop an intuitive feeling' for the physics and understand the numbers.
Also 1/r2 - 1/r1 does not equal 1/[itex]\Delta{r}[/itex] where [itex]\Delta{r}[/itex] = r2 - r1
~H
Hoot, I don't think Doc was referring to the conservation of energy, but rather how in your earlier post you used the change in distance to evaluate the change in pot. energy and thereby the change in KE .
Compare the first part of that post ( where you wrote the proper expression ) and the second part, where you use change in distance .
They don't match, do they ?:smile:
Arun
Edit : Astronuc's faster than me
Ahh, yes apologies everyone. I forgot that the particle started at a point in the electric field. I have edited by eroneous post.
~H
So I am really confused now.
The equation should read:
[tex]\frac{kQq}{0.55} - \frac{kQq}{x} = E_{k}[/tex]?
And Ek is [tex]\frac{kQq}{0.55} + 1/2mv^2[/tex]?
Therefore [tex]\frac{kQq}{0.55} - \frac{kQq}{x} = \frac{kQq}{0.55} + 1/2mv^2[/tex] ?
No, this is wrong.
KE is always 1/2mv^2
The expression should equate so :
Initial PE + Initial KE = Final PE (no KE)
Your equation that I quoted in post #11 is correct.
Hoot: As arunbg and Astronuc have pointed out, it was your mathematical step that I was objecting to. Nothing that an extra cup of coffee wouldn't cure. :wink:
[tex]\frac{kQq}{x} = E_{k} + \frac{kQq}{0.55}[/tex]
That last equation should be:
x is the distance the particle moves, not the final separation of the particles.
Yeah, I've sat down and figured it out. I wasn't fully concentrating on the post (I'm actually say here typing up revision notes and I just flick over to PF when I get bored and need a break). Guess I've learned my lesson about not fully concentrating.
Again, apologies to all for the confusion. As for the cup of coffee, that sounds like a grand idea.:tongue2:
~H
Alrighty based on the equation:
I found that x is equal to 0.32m, which is the distance that the particle moves before stopping.
Does this look a little better? This number seems more appropriate to me.
Wow this thread has grown quite a bit since my last visit :smile:
I know you guys have it all figured out now, but why not plug in the values only when you must? As Astronuc said, the physical feel is most important. Anyway I just felt like whining so I did it :biggrin:
1. What is a charge particle in motion?
A charge particle in motion refers to a charged particle, such as an electron or proton, that is moving through a magnetic field. The motion of the particle is affected by the magnetic field, causing it to experience a force and change direction.
2. What is the relationship between charge particles and magnetic fields?
Charge particles and magnetic fields have a strong relationship. When a charged particle moves through a magnetic field, it experiences a force perpendicular to both the direction of motion and the direction of the magnetic field. This force is known as the Lorentz force.
3. How does the speed of a charge particle affect its motion in a magnetic field?
The speed of a charge particle has a significant impact on its motion in a magnetic field. The faster the particle is moving, the stronger the force it experiences from the magnetic field. This means that the particle will curve more sharply and have a smaller radius of curvature.
4. What is the importance of studying charge particles in motion?
Studying charge particles in motion is crucial for understanding many natural phenomena, such as the behavior of charged particles in the Earth's magnetic field or the formation of auroras. It also has practical applications, such as in particle accelerators and MRI machines.
5. How is the motion of charge particles used in technology?
The motion of charge particles is utilized in various technologies, including electric motors, generators, and particle accelerators. It also plays a crucial role in telecommunications, as the movement of charged particles in wires allows for the transmission of electrical signals.
