Charge problem: two pith balls
In summary, the problem involves two charged pith balls suspended on light strings and an equilibrium angle between them. Using the equations for gravitational and electric forces, the distance between the balls and their charges can be calculated. After rearranging the equations and solving for q1, the final result is 4.44 x 10^-7 coulombs. There was a correction made for the distance between the balls, resulting in a final answer of 7.15 x 10^-7 coulombs.
bmandrade
63
Please check if i did this problem right..
two charged pith balls are suspended on very light 12. cm strings. Each has a mass of 10. . In equilibrium the total angle between the string is 50 degrees, Assuming that the pith balls are equally charged, what is the charg on each ball
Fe=kelq1l lq2l [tex]/[/tex] r2
the ratio of Fg/Fe= tan [tex]\theta[/tex]
Fg = mg
This is what I tried
I made a diagram in showing all forces in which the graciataional force is downward, the electric force is pointing outward since the two balls repel each other and then their is tension form the string which is upward and inward 25 degree angle since both balls make a 50 degree angle.
Fg= mg = .010 kg x 9.8 m/s2 = .098 N
Using the ratio
Fe = Fg/tan [tex]\theta[/tex]
= .098 N / tan (25)
= .21 N
Arranging this equation and solving for q1
r is the distance the distance between the two balls which can be calculated
sin 50 = x / 12
x = 9.2 cm = .092 m
q = [tex]\sqrt{}[/tex]((Fe X r2)/ k )
= [tex]\sqrt{}[/tex]( .21N X 5.12 / 9.0X109
= 4.44 X 10 -7 Coulombs
is it right?
I think it should be Fe is balanced with mg*Tan25.
The vertical weight component of the ball means that the tension in the string is mg/cos25 and the horizontal force will be sin25 of this in magnitude ... hence mg*tan25.
I also think the distance between the balls is given by twice the length of the cord times Sin25 - which is the displacement from the vertical of 1 ball. Hence the need to double it.
Ok so in this case then Fe= mg * tan 25= .098 N * tan 25= .046 N
and then for the distance between you are right
so the distance will be
sin 25 = x / 12
x = 5.07 cm X 2 = 10 cm = .1m
so plugging this new numbers the answer should be
7.15 X 10-7 coulumbs
1. What is the charge problem: two pith balls?
The charge problem: two pith balls, also known as the Coulomb's law experiment, is a physics experiment that involves two small balls made of lightweight, insulating material (such as pith or polystyrene) suspended from a string. The experiment aims to demonstrate the principles of electrostatic charge and how like charges repel each other while opposite charges attract.
2. How do you perform the charge problem experiment?
To perform the charge problem experiment, you will need two pith balls, a piece of string, a stand to suspend the balls from, and a charged object (such as a plastic rod). First, attach the string to the stand and suspend the two pith balls from the same point on the string. Next, bring the charged object close to one of the balls and observe any movement. Repeat this with the other ball. Finally, bring the charged object close to both balls and observe their movement towards or away from each other.
3. What is the significance of the charge problem experiment?
The charge problem experiment is significant because it helps us to understand the fundamental principles of electrostatics, which is the study of electric charges at rest. It also demonstrates the concept of Coulomb's law, which states that the force between two charged objects is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
4. What are some common sources of error in the charge problem experiment?
Some common sources of error in the charge problem experiment include external factors such as air currents, which can cause the pith balls to move even without the presence of a charged object. The experiment also assumes that the charges on the balls and the charged object are evenly distributed, which may not always be the case.
5. How can the charge problem experiment be applied in real life?
The principles and concepts demonstrated in the charge problem experiment have various real-life applications. For example, understanding the behavior of electric charges is essential in designing electrical circuits and devices. It is also used in industries such as electronics, telecommunications, and energy production. Additionally, the experiment can be used to explain natural phenomena like lightning and the aurora borealis.
