UMath1
- 361
- 9
My textbook said that field lines do not always represent the trajectory of a charged particle in a field. How would you find the trajectory then?
UMath1 said:My textbook said that field lines do not always represent the trajectory of a charged particle in a field. How would you find the trajectory then?
UMath1 said:Electrostatic field. The negatively charged particle is just let go from the positive end.
I am not familiar with the lorentz force.
UMath1 said:but if you shot it in the direction of a field line, then?
It will do that "in the first moment", but it won't do that in general, even if it starts at rest. If the field lines are curved, the particle won't follow them.berkeman said:If you just release a charged particle from rest, yes it will follow the E-field lines, because that's the direction of the Lorentz force when there is no B field.
Your doubt is right here. To follow a curved line it would need an acceleration component orthogonal to the field line, but that does not exist by definition of the field line.UMath1 said:Right, but the direction of the force constantly varies if the field line is curved as it often is between positive and negative charges. It should move tangent to the field line initially. But I am not sure if after it moves in that direction, it will still be acted on by the same field line.
mfb said:It will do that "in the first moment", but it won't do that in general, even if it starts at rest. If the field lines are curved, the particle won't follow them.
mfb said:Your doubt is right here. To follow a curved line it would need an acceleration component orthogonal to the field line, but that does not exist by definition of the field line.
UMath1 said:So how would it move?
UMath1 said:But the field lines for gravity point in a constant direction. When you have a positive and negative charge, the field lines take a curved path. If a charge carrier is released in the direction of one of these curved lines, a force tangent to the curved line will act on it causing acceleration tangent to the line. But after that I don't see where the force will act on it.
UMath1 said:yes
UMath1 said:Lets say I release a negative charge from the top of the blue charge.
In general it will not.ZapperZ said:Regardless of that, when you have a field such as this, for an electron, the trajectory will closely follow the field lines when you release the charge from rest.
A charge particle trajectory is the path that a charged particle takes as it moves through an electric or magnetic field. This can be calculated using equations from electromagnetism and the principles of particle motion.
To find the charge particle trajectory, you will need to know the initial conditions of the particle, such as its velocity and position, as well as the strength and direction of the electric or magnetic field it is moving through. You can then use equations such as the Lorentz force law and Newton's laws of motion to calculate the trajectory.
The charge particle trajectory is affected by several factors, including the strength and direction of the electric or magnetic field, the mass and charge of the particle, and the initial conditions of the particle. Other factors such as external forces, collisions with other particles, and relativistic effects may also play a role.
Yes, the charge particle trajectory can be changed by altering the strength or direction of the electric or magnetic field it is moving through. This can be done by manipulating the equipment or by changing the properties of the field itself.
Calculating the charge particle trajectory is important for understanding the behavior of charged particles in various fields. This has practical applications in fields such as particle physics, electronics, and space science. It also helps us to better understand the fundamental principles of electromagnetism and particle motion.
