Homework Help: Charged cylinder (electric field, rotor, divergence)
  1. Oct 10, 2009 #1
    Charged Cylinder has lenght L and radius a. Charge density increases within the equation rho = rho0(r/a)3 where rho0 is constant and r is distance measured from cylinder´s axis. Outside of the cylinder charge density is zero.
    a, Calculate the electric field inside and outside of the cylinder as a function of measured distance from cylinder´s axis.
    b, Calculate the divergence of the electric field , and the rotor also.
    c, What is the total charge of the cylinder?
    2. Relevant equations
    rho = rho0(r/a)3
    3. The attempt at a solution
    I draw a picture that shows electric field of cylinder. Is the picture drawn right?
    a, The total charge should be Q inside the surface area A right? So in distance R I use coulomb´s law and I got E = Q/(e0pi(2RL + 4(R-a)2 + 2a2) I divided cylinder in three parts (ball, top area of cylinder, and circular area of cylinder) is that right?
    When inside the cylinder: should I just take Vinside/Vtot * E * rho? Does it make sense?
    b, I don´t know what means to divergence and rotor. I konw the divergence means something like, how much flow is coming out or going in. And rotor means something differences between flows.
    Should the divergence be 0 because I don´t see how charged cylinder creates more Q or electricity??? What about the rotor?? How do I prove these?
    c, Total charge of cylinder is (Q/V)*V is that right? so it is V*rho and where r = a
Draft saved Draft deleted
