What Angle Does the Charged Mass Form with the Vertical Sheet?
In summary, the angle theta that the string makes with the vertically charged sheet can be found using the formula theta = arctan(qE/mg), where qE is the force of charge and mg is the force of gravity. After correcting for units, the calculations result in a value of 159 degrees, found using the tangent function.
Punchlinegirl
224
A charged mass on the end of a light string is attached to a point on a uniformly charged vertical sheet of infinite extent. The acceleration of gravity is 9.8 m/s^2 and the permittivity of free space is 8.85 x 10^-12 C^2/Nm^2. Find the angle [tex] \theta [/tex] the thread makes with the vertically charge sheet. Answer in units of degrees.
Given:
mass of ball= 1 g
Areal charge density of the sheet= 0.23 [tex] \mu C/m^2[/tex]
length of the string = 78.9 cm
Then force of charge= qE= q[tex] \sigma [/tex] / 2E_0
We did some of this problem in class and went through the long process of drawing a free body diagram and summing up the components, we found that it was easier to use the pythagorean theorem to solve for T.
I found that T= [tex] \sqrt (mg)^2 + (qE)^2 [/tex]
So T= [tex] \sqrt 96.04 + 1.32 x 10^-5 [/tex]
So T= 9.8.
Then I plugged it into what we got for the forces in the y-direction, which was [tex] \theta= cos^-1 (-mg/T) [/tex]
So theta= cos ^-1 (-9.8/9.8)
= 180 degrees which is wrong... can someone help me please?
Check your calculation of [itex]q E[/itex] and [itex]mg[/itex] (note that m = 0.001 kg). What's [itex]q[/itex]?
Well I stupidly forgot to change to kg, but I'm still getting the wrong answer.
[tex] T= \sqrt (mg)^2 + (qE)^2 [/tex]
mg= .001 * 9.8 = .0098
qE= [tex] q \sigma/2 E_o [/tex]
qE= 2.8 x 10^-7 * 2.3 x 10^-7 / 2 * 8.85 x 10^-12
qE= .00364
T= [tex] \sqrt (.0098)^2 + (.00364)^2 [/tex]
T= .0104
[tex] \theta = cos^-1 (-.0098/.0104) [/tex]
[tex] \theta= 159 degrees [/tex]
What's with the minus sign?
[tex] \theta= \cos^{-1} (mg/T) [/tex]
Your calculation would be a bit easier if you used:
[tex] \theta = \tan^{-1} (qE/mg) [/tex]
(This way you don't have to calculate T.)
1. What is a charged mass on a string?
A charged mass on a string is a physical system in which a mass is connected to a string and has an electric charge. This system has both gravitational and electromagnetic forces acting on it.
2. How is a charged mass on a string different from a regular mass on a string?
A regular mass on a string only experiences the force of gravity, while a charged mass on a string also experiences the force of electromagnetism due to its electric charge.
3. How does the charge affect the motion of the mass on the string?
The charge on the mass will interact with any external electric or magnetic fields, causing the mass to move in response to these forces. The direction and magnitude of the motion will depend on the strength and direction of the electric and magnetic fields.
4. Can a charged mass on a string be used to generate electricity?
Yes, a charged mass on a string can be used in a similar way as a generator. As the mass moves along the string, it creates a changing magnetic field which can induce an electric current in a nearby wire. This principle is used in some types of energy harvesting devices.
5. What are some real-world applications of a charged mass on a string?
A charged mass on a string is used in a variety of applications such as energy harvesting, sensors, and actuators. It can also be used in scientific experiments to study the interactions between electric and magnetic fields and moving charges.
