Calculating Resultant Force Vectors in a 2D System
In summary, the charges on the axes of a square attract each other, while the charges on the diagonal repel each other.
ranger
Lets say that we have a four positive and equally charged particles. They are located on the corners of a square.
Can someone show (by diagram) how the other three particles would affect anyone particle. Please show how you reslove the vectors into its componets and how you get the resultant (formulas please :smile: ).
--thanks
Projecting the forces onto axes:
say we choose two axes parallel to the sides of the square, then if the square side length is a, each one of the two charges on the axes will apply force equal to q^2/a^2 on its axis and 0 on the second one, and the charge on the diagonal will apply sin(pi/4)*q^2/(sqrt(2)a)^2=cos(pi/4)*q^2/(sqrt(2)a)^2=q^2/(sqrt(2)a^2) on each one of the axes
The force vectors on a point charge operate along the lines determined by the point charge and each of the other charges. If charges are opposite, the vector will point toward the other charge, and if the charge are the same sign, the vector will point away.
Okay then, so since the charges are the same, they would repel. I've put together a little image based on that.
http://img356.imageshack.us/img356/3092/vector1mb.png
Now I want to calculate the final position and magnitude of the particle that is being acted upon. For that I need the resultant vector. But how do I get that? It looks like the brown charge is in the place of where the resultant sould be. I'm thinking tail-to-tip here. This is getting very confusing.
The resultant force vector is the sum of each force vector contributing to the force.
So if one has 3 vectors (i, j, k are orthogonal unit vectors).
a1 i + a2 j + a3 k
b1 i + b2 j + b3 k
c1 i + c2 j + c3 k
then the resultant vector is simply
(a1 + b1 + c1) i +
(a2 + b2 + c2) j +
(a3 + b3 + c3) k
Since the problem is 2D (coplanar), the coefficients of k are zero
:smile:
a1 i + a2 j + a3 k
b1 i + b2 j + b3 k
c1 i + c2 j + c3 k
(a1 + b1 + c1) i +
(a2 + b2 + c2) j +
(a3 + b3 + c3) k
:smile:
I'm still knida confused. I see that you have a1 + b1 + c1, what do thoes mean. Did you reslove them into conponenets? If you did then how come you have 3 components? Arent we just using x and y axis.
thanks again
1. What are charged particles?
Charged particles are atoms or molecules that have a positive or negative electrical charge. These charges are caused by an imbalance of protons and electrons within the particle.
2. How do charged particles interact with each other?
Charged particles interact with each other through the electromagnetic force. Like charges repel each other, while opposite charges attract each other.
3. What are vectors in relation to charged particles?
Vectors are quantities that have both magnitude and direction. In the context of charged particles, vectors are often used to represent the direction and strength of the electromagnetic force between particles.
4. How are charged particles and vectors used in technology?
Charged particles and vectors are used in a variety of technologies, such as electric motors, generators, and particle accelerators. They are also used in electronics, such as in the creation and manipulation of electric currents.
5. What are some real-world applications of charged particles and vectors?
Some real-world applications of charged particles and vectors include X-ray machines, MRI scanners, and cathode ray tubes. They are also used in the production of electricity through hydroelectric dams and wind turbines.
