Can the Effects of Relativity be Detected in a Simple Wire Experiment?
In summary: In fact, it's a very simple and common example illustrating the point.In summary, the force between two wires is due to the current flowing through them and the charges on each wire. The current creates a force between the wires due to the charges being attracted to each other.
Rockazella
96
Here’s a quick thought I had.
Since electrons experience relativistic effects just like any other matter, would you be able to detect a mass increase in a wire if you sent a current through it?
The actual net movement of electrons in a current carring wire is very small. The actual electon drift velocity is not even close to c.
Einstein wrote in his second relativity paper that one might check out E=MC2 by weighing radioactive material at two different times and comparing the weight difference to the total radioactive energy emitted in between. He later admitted it was a foolish idea.
Isn't it true that the signals speed is near c? I guess I don't really understand what you mean by electron drift velocity, mind explaining?
The name is very discriptive. The actual speed of a single electron or its drift velocity is much smaller then c. Signal probogation on the other hand is a signifigent fraction of c. This is not an uncommon phenonemn, even in water waves a molecule of water remaings nearly stationary horizontanly as the wave passes.
On a similar note, in particle accelerators, they can get particles to go quite fast, so do the particles ever get heavy enough from their speed that putting a plumb line a few feet from the accelerator would be noticably perturbed when the accelerator is running? Granted, this wouldn't be as cheap as running a current through a wire.
Just what would that prove?
Even thought particle accelerators have had sufficient energy to push particles well beyond c, if we lived in the world of Newtonian Physics, they have been unable to. Why? because of relativity, the speeds achieved for the energy input match the predictions of relativity to many decimal places.
Integral: I don't understand your post, but my point was that maybe the paricle would get heavy enough to have a noticable attraction for the plumb line. I really doubt it though, it was just an idea.
Mr. Robin Parsons: According to relativtity, it should be unmeasurably heavier while hot, not the other way around. Maybe water condensation?
Johnathan, its a lot easier than you're making it out to be: since the particle accelerator has to accelerate the particle, you can tell exactly how much energy you put into the particle and then measure its speed. Even a mediocre particle accelerator puts enough energy into a particle to accelerate it well beyond C under Newtonian mechanics. So the relativistic effects are clear as day.
Oh! Upon rereading Integral and Russ_water's posts, They are clear know, I don't know how I missed the point before.
Probably not.
But there is an easy relativistic explanation of forces between parallel wires:
Let's assume that positive charges are at rest, and negative charges flowing (OK, OK,...)
Imagine how one electron in wire A 'sees' wire B.
- If the currents have the same direction, then the electron will see the positive charges length-contracted, i.e. condensed. No change on negative charges. So wire B appears net positive, so attraction.
- If the currents have opposite directions, then the positive charges appear condensed, but the negative charges more condensed. So net negative charge, so repulsion.
I know that drift velocities are only some cm/s, but on the other hand you have a very large number of electrons. When doing the math, you arrive at the correct force, believe me.
And of course, this doesn't 'prove' anything about relativity.
1. What is relativity?
Relativity is a theory developed by Albert Einstein that explains how the laws of physics apply to objects in motion, specifically at high speeds or in the presence of strong gravitational fields. It includes the theories of special relativity and general relativity.
2. Why is it important to test relativity?
Testing relativity allows us to verify the validity of the theory and its predictions. It also helps us better understand the nature of the universe and how it functions. Furthermore, it can lead to advancements in technology and our understanding of fundamental physics.
3. What are some methods for testing relativity?
There are several ways to test relativity, including measuring the bending of light from distant stars due to the gravity of massive objects, observing the behavior of clocks in different gravitational fields, and testing the predictions of special relativity using high-speed particles.
4. Is it possible to test relativity without expensive equipment?
Yes, there are some simple experiments that can be done to test certain aspects of relativity, such as measuring the time dilation of a moving clock using a high-precision stopwatch. However, more complex experiments may require specialized equipment and technology.
5. What are the potential implications of disproving relativity?
If relativity were to be disproven, it would require a major overhaul of our understanding of physics and the universe. It would also call into question many other theories and laws that are based on relativity. However, it is unlikely that relativity will be disproven as it has been extensively tested and confirmed through numerous experiments and observations.
  • DIY Projects
