Friction Problem with Pulley System: Determining Acceleration and Force
In summary, the conversation involved two children playing on a pulley system and determining various values related to their movement. The question consisted of four parts, with the first part asking for the maximum value of static friction needed for the larger child to begin sliding. The second part involved finding the acceleration of the children once they start sliding, given a coefficient of kinetic friction of 0.2. The third part required determining the additional mass the sliding child should hold to maintain a constant speed. Finally, the fourth part involved calculating the force needed from their father to start the children sliding, using the value of static friction from the first part. The equations used were mg-umgcos(theta)=ma and 650=(.2)(850+10
groundhog92
There are 4 parts to this question. Two children are playing on a pulley system. A 65 kg child jumps of a platform pulling an 85 kg child horizontally across a platform. a) what is the maximum value for static friction to allow the larger child to begin sliding? b) Once sliding the coefficient of kinetic friction is .2 what will the acceleration of the children be? c) How much additional mass should the sliding child hold to maintain a constant speed? d) If their father comes and offers to pull them both, using the value of static friction from part a) how much force would he need to exert in order to start the children sliding?
mg-umgcos(theta)=ma
part a
650=u(850)
u=.76
part b
650-(.2)(850)=150a
a=3.2m/s^2
part c
650=(.2)(850+10x)
10x=2400
x=240kg
part d
1500(.76)=F
F=1140
Note: This is rounding gravity to 10 from 9.81 (My teacher says we need learn the process and he doesn't really care about us simplifying the math)
I think I have this right, but we have to do these up in front of the class on the board so I wanted to make sure.
sorry if it wasn't clear
I meant u to be the coefficient of friction
Your approach to the problem is correct. However, there are a few things that could be improved upon in your solution. First, in part a, you are using the weight of the larger child (850 N) instead of the force that is actually acting on the larger child (650 N). This would lead to an incorrect value for the coefficient of static friction. The correct equation to use would be 650=u(650), which would give a coefficient of static friction of 1. This means that the maximum value for static friction is equal to the weight of the larger child, and any value below that would allow the larger child to begin sliding.
In part b, you are using the incorrect value for the force acting on the children. The correct equation to use would be 650-(0.2)(650)=150a, which would give an acceleration of 2 m/s^2. This is because the force acting on the children is not their combined weights, but rather the difference in their weights (650 N).
In part c, you have correctly calculated the additional mass needed for the sliding child to maintain a constant speed. However, it is important to note that this additional mass should be added to the weight of the sliding child (850 N), not the weight of both children combined (1500 N).
In part d, you have correctly calculated the force needed to start the children sliding. However, it is important to note that this force should be applied in the opposite direction of motion (towards the left), as it is acting against the force of friction.
Overall, your solution shows a good understanding of the concepts involved in the problem, but there are small mistakes in the calculations that should be corrected. Keep up the good work!
1. What is friction?
Friction is the force that resists the relative motion or tendency to motion between two surfaces in contact with each other.
2. How is friction related to the laws of motion?
Friction is related to Newton's laws of motion as it is a force that acts in the opposite direction of an object's motion, according to the third law of motion.
3. How do you calculate friction?
The formula for calculating friction is μ = F/N, where μ is the coefficient of friction, F is the force of friction, and N is the normal force between the two surfaces.
4. What factors affect friction?
The factors that affect friction include the type of surfaces in contact, the force pressing the surfaces together, and any roughness or irregularities on the surfaces.
5. How can friction be reduced?
Friction can be reduced by using lubricants, such as oil or grease, between the surfaces, by using smoother surfaces, or by reducing the force pressing the surfaces together.
15K
