Solving for Max Height & Side Lengths of Triangle Inclined at 24 Degrees
In summary, the given problem involves finding the maximum height of a rectangle and the maximum side lengths of an isosceles triangle on an incline of 24 degrees. The incline angle and the center of mass at 90 degrees are used in the solution, and trigonometry is applied. The maximum height of the rectangle is found to be 2.964 meters, while the maximum side lengths of the triangle are found to be 4.449 meters and 4.4958 meters.
tachu101
74
Given a isosceles triangle with base 1.32 meters and other sides unknown; Given rectangle with base 1.32 meters. These polygons are on an incline of 24 degrees. What are the maximum height of the rectangle and the maximum side lengths of the triangle (not the base) without have the objects tip over.
The incline angle and the center of mass at 90 degrees is what the question is asking for. So the incline (24 degrees) + (unknown angle) = 90 so right away I know that the angle must be 66 degrees. Then I think that some trig comes into play.
If you take half of the rectangle (to make a triangle) you can find the height of the rectangle by doing 1.32tan66=height which would get 2.964 meters. (is this the maximum height)?
The triangle is more complicated. I did the same thing and broke the triangle in half so 1.32 becomes .66 for the base. This then goes into .66tan66= height from base to the center of mass (centroid) which comes out to 1.4823 meters .
Then I think that the length of the base to the centroid and the length from the centroid to the top of the triangle is in the relationship of 1:2. So I tripled the 1.483 to get 4.449 meters as the length of the altitude.
Finally I use the Pythag Therm to get 4.449^2+.66^2= 4.4958 meters (and I think this is the answer)
Your method looks good. (You may want to recheck your arithmetic, looking for round-off errors.)
I would first commend the student for their attempt at solving the problem using trigonometry and the Pythagorean theorem. However, I would suggest that they review the concepts of center of mass and centroid, as they are not the same thing. The center of mass is the point at which the object's mass is evenly distributed, while the centroid is the geometric center of the object. In this case, the centroid of the triangle would be located at the intersection of the medians, not the center of mass.
Additionally, I would recommend using a free body diagram to analyze the forces acting on the objects and determine the maximum height and side lengths without tipping over. This would involve considering the weight of the objects, the angle of incline, and the normal force acting on the objects.
Overall, the student's approach is a good start, but further research and understanding of the relevant concepts would be necessary to accurately solve the problem.
1. How do you determine the maximum height of a triangle inclined at 24 degrees?
The maximum height of a triangle inclined at 24 degrees can be determined by using the sine function. The formula for determining the maximum height is: maximum height = side length x sin(24 degrees). This equation takes into account the angle of 24 degrees and the length of one of the sides of the triangle.
2. Can you solve for the side lengths of a triangle inclined at 24 degrees?
Yes, the side lengths of a triangle inclined at 24 degrees can be solved using the Pythagorean theorem. The formula for solving for the side lengths is: side length = maximum height / sin(24 degrees). This equation takes into account the maximum height and the angle of 24 degrees.
3. What is the significance of a triangle being inclined at 24 degrees?
The angle of inclination in a triangle is important because it determines the shape and size of the triangle. In the case of a triangle inclined at 24 degrees, it means that one of the angles in the triangle is 24 degrees, which affects the length of the sides and the height of the triangle.
4. Are there any real-world applications for solving for max height and side lengths of a triangle inclined at 24 degrees?
Yes, this type of problem often arises in engineering and construction, where it is important to know the maximum height and side lengths of a triangle in order to properly design and build structures.
5. Can this problem be solved using other geometric principles?
Yes, there are several other geometric principles that can be applied to solve for the max height and side lengths of a triangle inclined at 24 degrees. These include the law of cosines, the law of sines, and the Pythagorean theorem.
  • General Math
