1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Check: Temperatue Distribution On a Long Hollow Rod
  1. Nov 9, 2008 #1
    Consider a hollow rod whose initial normalized temperature is unity. At time zero
    its normalized outside temperature is suddenly changed to zero. The inside surface
    is perfectly insulated. The normalized equation and the BCS and IC are given as:
    [​IMG]
    urr+[tex]\frac{1}{r}[/tex]ur=ut
    ur(a,t)=0
    u(1,t)=0
    u(r,0)=1
    Find the function for expressing the temperature distribution.
    2. Relevant equations
    None
    3. The attempt at a solution
    [tex]\frac{\partial u}{\partial t}=\alpha[\frac{\partial^{2}u}{\partial r^{2}}+\frac{1}{r}\frac{\partial u}{\partial r}][/tex]
    u(r,t)=R(r)G(t)
    [tex]\frac{1}{\alpha G}\frac{dG}{dt}=[\frac{1}{R}\frac{d^{2}R}{dr^{2}}+\frac{1}{Rr}\frac{dR}{dr}]=-\lambda^{2}[/tex]
    [tex]\frac{d^{2}R}{dr^{2}}+\frac{1}{R}\frac{dR}{dr}+\lambda^{2}R=0[/tex]
    [tex]R(r)=A J_0(\lambda r)+B Y_0(\lambda r)[/tex]
    [tex]J_0(\lambda_n a)=0[/tex] because [tex]A J_0(\lambda_n a)\neq0[/tex]
    [tex]u(r,t)=\sum_{n=1}^{\infty}a_n J_0(\lambda_n r)e^{-\lambda_n^{2} \alpha t}[/tex]
    [tex]u(r,0)=1=\sum_{n=1}^{\infty}a_n J_0(\lambda_n r)[/tex]
    [tex]A_n=\frac{\int_0^{a}r J_0 (\lambda_n r)dr}{\int_0^{a}r J_0^{2} (\lambda_n r)dr}=\frac{2}{a \lambda_n J_1(\lambda_n ,a)}[/tex]
    [tex]u(r,t)=\frac{2}{a}\sum_{n=1}^{\infty}\frac{1}{\lambda_n}\frac{J_0(\lambda_n r)}{J_1(\lambda_n a)}e^{-\lambda_n^{2} \alpha t}[/tex]
    Looks like an expression for temperature distribution to me. What do you guys think?
Similar Discussions: Check: Temperatue Distribution On a Long Hollow Rod
  1. A long-shot request (Replies: 0)
  2. Answer need checking! (Replies: 0)
  3. Heated rod problem (Replies: 0)
Loading...
