Chemically dissolve aluminum?
  • Thread starter bikeguy
50
I've dissolved aluminum foil in methanol when I used a sonicator.
Can you detail? I didn't know it.
chemisttree
679
I was trying to ultrasonically clean a bit of aluminum foil and I chose methanol as a solvent. After a couple of minutes in the sonicator... swiss cheese. It made aluminum methoxide I believe. Kind of dangerous and I didn't repeat it.
morrobay
427
Sodium hydroxide does dissolve aluminum.
We used to make "gas" baloons by adding aluminum foil to a lye solution.
2H2O + 2NaOH +2Al ---> 2NaAlO2 + 3H2
Clarification :
2Al + 6NaOH ---> 2Na3AlO3 + 3H2
This is a more accurate since the water in the first reaction just moves the ions around during the reaction and is not involved in hydrogen being reduced to hydrogen gas
50
Clarification :
Are you sure Na3AlO3 really exists? Anyway, I don't see any problem in the previous reaction you wrote:
2Al + 2NaOH + 2H2O ---> 2NaAlO2 + 3H2
Borek
Mentor
28,881
3,429
Compounds like aluminates are notoriously difficult to describe, as their composition - in terms of number of water molecules and OH- attached to the cation - is a matter of multistep equilibrium. Hence you will find different formulas in different sources.
  • #31
1,938
50
Yes, this is true, but that one I've never seen it before.
  • #32
morrobay
427
Hello, no im not sure it exists ,but i dont have a problem with 3Na and AlO3
in solution.
The problem with the previous reaction i was having is that it implies that the hydrogens
in the two waters are reduced/released in the product as hydrogen gas.
And I could not see any mechanism for that in the reaction with NaOH and Al.
If you can describe that mechanism I would appreciate it
(please place the pos & negs over the ions)
  • #33
1,938
50
in solution.
Al reacts with water when the oxide layer is removed:
2Al + 3H2O --> Al2O3 + 3H2
NaOH dissolves the oxide layer.
Related Threads on Chemically dissolve aluminum?
  • Last Post
  • Last Post
17K
  • Last Post
  • Last Post
  • Last Post
