Homework Help: Chemistry Problem III
  1. Sep 26, 2007 #1
    Question:
    Given
    mass of hexaammine complex [Ni(NH3)6](NO3)2 is 0.0937 g
    mass of Ni2+ is 0.0193 g
    if the mass of [Ni(NH3)6](NO3)2 was 0.0886 g instead of 0.937g, this would indicate that the hexaammine complex was not pure and some ammonia had been lost. Calculate the value of n in the formula [Ni(NH3)n](NO3)2
    my attempt:
    - Take the mass of Ni2+ and find the moles of it using Ni2+ molar mass. This mole would then be the same as the moles of the complex (1:1 ratio) --> i found to be 0.0003288 moles
    - then take the grams of the complex 0.0886 g and divide by that mole: 0.0886g/0.0003288moles = 264.4404 g/mol which would be the molar mass of the complex
    - then i subtracted the molar masses of Ni2+ and (NO3)2 from that molar mass and what is left is the amount of (NH3)n. Then i took that amount and divided by the molar mass of one NH3 to see how many NH3 I have.
    am I thinking right?
  3. Sep 27, 2007 #2
    chemisttree
    You are well on your way.
  4. Sep 29, 2007 #3
    i keep getting the wrong answer....what am i doing wrong?
  5. Sep 29, 2007 #4
    so here is what i did
    0.0193g Ni x (1 mol Ni/58.693g) x (1mol [Ni(Nh3)6](NO3)2/ 1 mol Ni) = 3.288 E-4 moles of [Ni(Nh3)6](NO3)2
    then i took 0.0886g and divide by this moles to get the molar mass
    0.0886g/3.288 E-4 moles [Ni(Nh3)n](NO3)2
    = 269.44 g/mol
    then i substracted Ni (58.693g/mol) and (NO3)2 (124.008g/mol) from that molar mass
    269.44 - 58.693 - 124.008
    86.739 g/mol
    then take this number and divide by (NH3) molar to see how many NH3 there are:
    (86.739g/mol) / (17.031g/mol)
    = 5.09 NH3
    so n is equal to 5.09.... this answer is still incorrect when i entered into the computer for grading ><
    what am I doing wrong!!!!!!!!!??????????
  6. Sep 29, 2007 #5
    did you enter 5 or 5.09? n should be a whole number
  7. Oct 2, 2007 #6
    chemisttree
    How many significant figures are you asked to provide? Generally you would use an integer value if you were trying to determine the empirical formula for a pure substance. In this case the sample may be a mixture of the hexamine, pentamine, etc... and so a non-integer value for n may be correct.
