• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Chemistry question - help
  • Thread starter howie222
Hello everyone.
I came here because I'm having trouble with a chemistry question an you guys seem to know what you're talking about =)
I need to sepearate Ag^+, Ca^2+, and Ni^2+ ions from a solution. each of these is at a 0.1M concentration.
I've never done this type of question before... what method should I be looking in to?
I'm thinking maybe I could form precipitates by adding certain anions.. but I'm not sure which ones, I'm also not sure if order matters or when I should be filtering.
would someone be kind enough to point me in the right direction? :smile:
thanks
this link describes theory & methods to separate your indicated metal ions. it's fairly detailed in the experimental procedures.
http://www.csun.edu/~hfchm006/CationSeparation.pdf [Broken]
thanks for the link!
1) First remove the Ag+ ions by adding HCl(aq) which will precipitate as AgCl(s)
2) Filter
3) Remove the Ni^2+ ions by adding H2S(aq) which would form a NiH(s} precipitate.
4) filter
5)Remove the Ca^2+ ions by adding (NH_4)_2CO_3 forming a precipitate with ????
6) filter
and the ions are removed.
but what about the fact that I was given .1M concentration for each....am I supposed to have specific amounts that need to be added? or can i just add until the precipitate stops forming?
altho you are told each metal ion conc = 0.1M, you are not told how much total solution you have to work with. therefore, you can't specify exact reagent amounts to add.
unless you provide your own "example" metal ion solution amount (say 100 ml), you can only specify to add reagent until precip stops (which will be reagent in slight excess of exact amount required).
however, if you take an example amount of 100 ml metal ion solution and example reagent solutions of 1M conc, then you can calculate approximate amounts of reagent to add, altho you will still want to add slight excess of reagent.
thanks for your response =) I think you're right, but at the same time its a little odd that they would give me the concentrations....
can i get a confirmation from someone? I'm pretty sure that I'm right based on that document you showed me, but just want to make sure.
thanks
anyone?
just want to make sure that i dont have to do anything with the fact that they all have a concentration of .1 M
siddharth
Have you learnt about selective precipitation of salts, and significance of using ksp values? In that method, the concentration of the metal ion is required.
Also, when you add H2S to Ni2+, the precipitate is NiS (black ppt) and not NiH.
thanks for the response, yes I did learn about Ksp values, and their significance, but its been awhile :smile: I'll look into that now.
also,
any idea what precipitate this would form?
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
