Solving Chemistry: Calculating Minimum Mg Mass for Neutralizing H2SO4
  • Thread starter titchwatt
  • Tags
    Chemistry
In summary, the conversation is about calculating the minimum mass of magnesium metal needed to neutralize 0.50 L of 1.0 mol/L sulfuric acid. The calculations involve determining the number of moles of H2SO4 in 0.5 L and using the molar ratio to find the number of moles of Mg needed. The relation between atomic weight, number of moles, and mass is used to find the final answer.
titchwatt
I was wondering if anyone could point me in the right direction for this question ?
Mg + H2SO4 ----> MgSO4 + H2
Cacluate the minimum mass of magnesium metal that would be required to completely neutralise 0.50 L of 1.0 mol l-1 sulfuric acid.
My calculations so far ...
Mr(H2SO4) = 2xAr(H) + Ar(S) + 4xAr(O)
= 98
Mr(MG) = 24.31
Molarity = 1.0mol / 0.50L = 2
But I am at a loss as to how I get to the final answer ...
Any help would be most appreciated !
From the reaction you have written, 1 mole of H2S04 is neutralised by 1 mol of Mg. So, what is the number of moles of H2S04 in .5 L? And this will require how many moles of Mg?
Thanks for the reply,
It states that there is 1.0mol of sulfuric acid so the amount of magnesium required would be 1.0mol as well ?
No, it states that there is 1.0 mol per litre of sulphuric acid. So, in 0.5 litres, how many moles are there? That will be equal to the number of moles of Mg required.
Once you find the number of moles of Mg required, do you know how to find the mass of Mg? (Hint: What is the relation between atomic weight, number of moles and mass of the substance?)
That has helped a lot ! Thankyou.
1. What is the purpose of calculating the minimum Mg mass for neutralizing H2SO4?
The purpose of this calculation is to determine the minimum amount of magnesium (Mg) needed to completely neutralize a given amount of sulfuric acid (H2SO4) in a chemical reaction.
2. How is the minimum Mg mass calculated?
The minimum Mg mass is calculated using the balanced chemical equation for the reaction between Mg and H2SO4. The coefficients of the reactants in the equation are used to determine the mole ratio between Mg and H2SO4, which is then used to convert the given amount of H2SO4 to the corresponding amount of Mg.
3. What units are used for the minimum Mg mass?
The minimum Mg mass is typically expressed in grams (g) or milligrams (mg), depending on the amount of H2SO4 being neutralized. However, it can also be expressed in other units such as moles (mol) or kilograms (kg) if needed.
4. Why is it important to calculate the minimum Mg mass?
Calculating the minimum Mg mass is important for ensuring the efficiency and accuracy of a chemical reaction. It allows scientists to determine the exact amount of Mg needed to neutralize a certain amount of H2SO4, preventing wastage of resources and ensuring the desired outcome of the reaction.
5. Are there any limitations to this calculation?
Yes, there are some limitations to this calculation. It assumes that the reaction between Mg and H2SO4 is stoichiometric, meaning that it occurs in perfect proportions according to the balanced chemical equation. In reality, there may be other factors that could affect the reaction and its outcome, such as impurities in the reactants or side reactions.
10K
27K
