Chemistry Reduction Reaction Help Needed
  • Thread starter VinnyCee
Chemistry Reduction Reaction Help Needed: MnO4- + S2- --> MnO2 + S8
I was wondering if I had done this reduction reaction equation correctly:
[tex]MnO_4^-+S^{2-}\xrightarrow{}MnO_2+S_8[/tex]
After going through the reduction reaction problem solving process (I think) I get this equation as the final equation in the reaction:
[tex]2MnO_4^-+3S^{2-}+4H_2O\xrightarrow{}2MnO_2+3S_8+8OH^-[/tex]
Does this look correct? Can anyone check? Thanks.
Answers and Replies
Here is a more detailed explanation of the answer I have
Ok, starting with the original equation:
I then seperate into two "half-reactions":
[tex]MnO_4^-\xrightarrow{}MnO_2[/tex]
[tex]S^{2-}\xrightarrow{}S_8[/tex]
Figureing the oxidation charge for the left side of the first "half-reaction":
[tex]X-8+1=0\xrightarrow{}X=7[/tex]
Therefore, the oxidation number of Mn on the left side is 7, right?
Then I do the right side of the first "half-reaction":
[tex]X-4=0\xrightarrow{}X=4[/tex]
This means that the oxidation number of Mn on the right side is 4. Meaning that I have to add 3 electrons to the left side of the first "half-reaction" equation, right?:
[tex]MnO_4^-+3e^-\xrightarrow{}MnO_2[/tex]
Now, I added H+ ions to the left side to bring it's overall charge down to zero, because the right side has an overall charge of zero:
[tex]MnO_4^-+3e^-+4H^+\xrightarrow{}MnO_2[/tex]
Finally, I add H2O to even out the oxygens in the first "half-reaction" equation:
[tex]MnO_4^-+3e^-+4H^+\xrightarrow{}MnO_2+2H_2O[/tex]
Going on to the second of the two "half-reaction" equations:
The oxidation number for the left hand side of the second "half-reaction" equation is -2 and for the right side it is 0, right? So then I added 2 electrons to the right side of the second "half-reaction" equation:
[tex]S^{2-}\xrightarrow{}S_8+2e^-[/tex]
I then multiply the two results from the "half-reaction" equations in order to eliminate the electrons:
[tex](MnO_4^-+3e^-+4H^+\xrightarrow{}MnO_2+2H_2O)*2=2MnO_4^-+6e^-+8H^+\xrightarrow{}2MnO_2+4H_2O[/tex]
[tex](S^{2-}\xrightarrow{}S_8+2e^-)*3=3S^{2-}\xrightarrow{}3S_8+6e^-[/tex]
Adding them together, I get:
[tex]2MnO_4^-+3S^{2-}+8H^+\xrightarrow{}2MnO_2+3S_8+4H_2O[/tex]
Finally, I add OH- to balance and eliminate the H2O's on the right side:
[tex]2MnO_4^-+3S^{2-}+8H^++8OH^-\xrightarrow{}2MnO_2+3S_8+4H_2O+8OH^-[/tex]
[tex]2MnO_4^-+3S^{2-}+8H_2O\xrightarrow{}2MnO_2+3S_8+4H_2O[/tex]
[tex]2MnO_4^-+3S^{2-}+4H_2O^+\xrightarrow{}2MnO_2+3S_8+8OH^-[/tex]
Does this seem reasonable?
your final line: [itex] ... 4H_2O^{+} [/itex] ?
and the sulfur is not balanced.
How do I balance the equation then? Did I do the "half-reaction" equations correctly?
Do you see where I made a mistake?
Thanks again.
Redoing the problem
I did it again by starting with an actual balanced equation:eek:
Ok, starting with the original equation (now balanced):
[tex]MnO_4^-+8S^{2-}\xrightarrow{}MnO_2+S_8[/tex]
[tex]8S^{2-}\xrightarrow{}S_8[/tex]
[tex]8S^{2-}\xrightarrow{}S_8+2e^-[/tex]
[tex](8S^{2-}\xrightarrow{}S_8+16e^-)*3=24S^{2-}\xrightarrow{}3S_8+48e^-[/tex]
[tex]2MnO_4^-+24S^{2-}+8H^+\xrightarrow{}2MnO_2+3S_8+4H_2O[/tex]
[tex]2MnO_4^-+24S^{2-}+8H^++8OH^-\xrightarrow{}2MnO_2+3S_8+4H_2O+8OH^-[/tex]
[tex]2MnO_4^-+24S^{2-}+8H_2O\xrightarrow{}2MnO_2+3S_8+4H_2O+8OH^-[/tex]
[tex]2MnO_4^-+24S^{2-}+4H_2O^+\xrightarrow{}2MnO_2+3S_8+8OH^-[/tex]
Related Threads on Chemistry Reduction Reaction Help Needed
23K
  • Last Post
  • Last Post
20K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
