Circle & Infinity: Why Is a Line?
In summary, the conversation discusses the concept of a circle with an infinite radius and its relationship to a line. It is debated whether a circle with an infinite radius can even exist, and it is suggested that it would approach a straight line in the limit. The conversation also touches on hyperbolic geometry and the idea of a "horocycle". The conversation ends with a personal anecdote about a student's musings on the concept of a line being an arc of a circle with infinite radius.
mathlove3.14159
Why is it that a circle with an infinitly large radius is a line?
Why is it that this planet looks flat to our point of perception?
Depends on your definition of "circle".
There is no such thing as a "circle with infinite radius". What is true is that the "curvature" of a circle with radius R is 1/R. In the limit, as the radius goes to infinity (which NOT the same as saying the radius is infinite!), the curvature goes to 0 and the only "curve" having curvature 0 at every point is a straight line.
By the way, in hyperbolic geometry, the limit of a sequence of circles, having the same center but increasing radius, is NOT a straight line but a "horocycle".
Depends on your definition of "circle". In complex analysis we sometimes see a definition of "circle" that includes lines. That way it doesn't matter whether we think of the complex numbers as a plane (Argand) or a sphere (Riemann).
A curve is line because as the radius becomes larger, it becomes like a line. Try it in your compass.
And make sure you have a really big compass.
Are you asserting that "like a line" and "is a line" are the same?
I will point out again that in hyperbolic geometry, if you take circles passing through a given point with larger and larger radius, they "look" more and more like a line but the limiting figure is a "horocycle", NOT a line.
Consider a circumscribed n-agon. Join each vertex of one of the sides AB to the centre O. The length of the sides of AO and BO would be the radius of the circle r.
The area of the triangle AOB using the trigonometry equation would be
½ AO*BO sin {360/n} or ½ r^2 sin{360/n}
The area of the n-agon would be n*1/2 r^2 sin {360/n}
As n-> infinity the area of the n-gon approaches the area of the circle
Or n/2 * r^2 sin {360/n} -> pi r^2
We can eliminate r^2 from the equation thus:
n/2 * sin{ 360/n} -> pi as n-> infinity
Let n = 1000000 which is very big but still far from infinity.
n/2* sin{ 360/n} –pi =-0.0000000000206932385 which is close.
This result points to the fact that as the number of straight sides of the n-agon approaches infinity the circle and n-agon become closer to being identical.
Consider then the perimeter of the n-agon and the circumference of the circumscribing circle.
Let the base of our triangle be s and the two radius long sides r.
s/sin(360/n)= r/sin ((180-360)/2)
this simplifies to s=r*sin(360/n)/((sin180*n -360)/2)however as N->infinity
sin180*n-360)/2->sin90degrees=1
so n*s =n/2*sin(360/n) and this we know ->pi as n->infinity.
We might consider the circle as being an infinity-sided polygon.
Did you notice that this thread is three years old?
How do people find such old threads?
R.I.P.
When I was 12 in a maths lesson I was doing simple equations the answers of which were of the form x=3 etc. We were required to double underline our answers. Being 12 I used the curved edge of my protractor and for the short answers the arc of 10 degrees seemed straight to me. I figured if I had a bigger protractor I could draw a 10 degree arc that would be longer and still look straight my mind followed bigger and bigger protractors to the conclusion that a straight line is the arc of a circle of infinite radius. I turned to the back of my maths book and wrote this down. Just then I received a blinding cuff to the back of my head by my teacher and was toldto , "Get on with your maths boy".
As I grew oder this still perplexed me and I thought about it often. What I wrote in my initial posting was part of my musing.
How did I find this particular posting? I entered my statement made all those years ago in Google and it sent me here.
1. What is a circle and infinity?
A circle is a closed shape with all points equidistant from the center. Infinity is a concept that refers to something without any limit or end.
2. Why is a line used to create a circle?
A line is used to create a circle because it represents the continuous and infinite nature of a circle. A line can be drawn around a fixed point, creating a continuous and unbroken shape.
3. How does a circle relate to infinity?
A circle and infinity are closely related because a circle is a representation of infinity. It has no beginning or end and can be infinitely divided into smaller parts.
4. What is the mathematical equation for a circle?
The mathematical equation for a circle is (x - h)^2 + (y - k)^2 = r^2, where (h,k) is the center of the circle and r is the radius.
5. What real-life applications use the concept of a circle and infinity?
The concept of a circle and infinity has various real-life applications, such as in geometry, architecture, engineering, and physics. The shape of a wheel, globe, and clock are all based on the concept of a circle and infinity.
  • Calculus
  • General Math
  • Linear and Abstract Algebra
  • General Math
