Circuit analysis question?
  1. Jun 30, 2013 #1
    We have the circuit.http://i.imgur.com/X4IYi4j.jpg
    Find the equivalent thevenin resistance ..the result in my book is 8 ohm but I alway get 8/6 ..how so?
    2. Relevant equations
    Thevenin Teorem
    3. The attempt at a solution
    1/Re=1/4+1/2 and so Re=8/6 ..
  3. Jun 30, 2013 #2
    gneill
    Staff: Mentor
    You'll have to show your work so we can see where you are going wrong. Is R4 part of the circuit for which you want to find the Thevenin equivalent, or does it represent the load?
  4. Jun 30, 2013 #3
    I dont calculate R4 because I have to use the Tevenin's transformation between the points a and b..to find equivalent resistance, I took the R3 and R2 in parallel and found 1/Re=1/R3+ 1/R2
  5. Jun 30, 2013 #4
    rude man
    I get R thevenin = 80/21 ohms. I included R4.
    Without R4 I get R thevenin = 5 ohms.
  6. Jun 30, 2013 #5
    gneill
    Staff: Mentor
    So R4 is not part of the circuit under analysis. Fine.
    What makes you think that R2 and R3 are in parallel? Even if you could suppress the two current sources (which you can't because one of them is an active source), wouldn't that leave the resistors in series?
    You'll have to use another method to find the Thevenin equivalent since you have an active source in the circuit.
  7. Jun 30, 2013 #6
    Rude man,how about without R4?
    I they are in series,than the result is 6 ,still different from my book..
  8. Jun 30, 2013 #7
    gneill
    Staff: Mentor
    The controlled source is going to muck with the Thevenin resistance. You need another analysis method.
    @rude man: I'm seeing the book's answer of 8Ω.
  9. Jun 30, 2013 #8
    rude man
    As gneill pointed out, you have to include the effects of the voltage-dependent voltage source. You can't just parallel resistors etc.
    The way I do it is to apply 1V to the input, then compute the input current i using KVL or whatever, then R thevenin = 1/i.
  10. Jun 30, 2013 #9
    rude man
    Looks like I struck out on this one! :blushing:
  11. Jun 30, 2013 #10
    gneill
    Staff: Mentor
    Hey, you do good work. A small slip every now and then can't be avoided. Besides, they tend to rejuvenate concentration :smile:
  12. Jun 30, 2013 #11
    rude man
    Still bugs me. Want to send me your analysis privately?
  13. Jun 30, 2013 #12
    gneill
    Staff: Mentor
    Sure, I'll see if I can slip it into a PM.
  14. Jul 5, 2013 #13
    NascentOxygen
    Staff: Mentor
    i'm disappointed that you appear to have given up on this question. I seem to have worked it out needlessly, then. :smile:
    Perhaps someone else would like clues on how to do it? It's a good exam-type question. :wink:
  15. Jul 6, 2013 #14
    The circuit isnt very clear but if there's 2 power sources then Kirchhoff's voltage law and the use of simultaneous equations would be helpful
Have something to add?
Draft saved Draft deleted
Similar Discussions: Circuit analysis question?
Loading...
