Circuits and Terminal Voltage
In summary, the problem involves three equal resistors connected to a battery with an emf of 15V and an internal resistance of 0.5 ohms. When the switch is closed, the terminal voltage can be calculated using V=IR, which gives a value of 14.1V. When the switch is open, the terminal voltage can be calculated using V terminal = E- Ir, which also gives a value of 14.1V. The solution involves treating the resistors as both parallel and series circuits.
mer584
39
Three equal resisters are connected to a battery. If the emf of the battery is 15V, what is its terminal voltage when the switch is closed if the internal resistance is 0.5 ohms and R= 5.5ohms? What is the terminal voltage when the switch is open.
V=IR; V terminal = E- Ir
jpg.gif Untitled.jpg (7.6 KB)
See Picture
So I'm not sure if you need to apply Kirchhoffs rules here or not. It seems simple enough that you might not have to?
I first tried treating everything vertically as parallel and then adding it to the horizontal R as though it were in series
Then I tried adding everything in the first box as though it were in series and adding that to the outside R as though they were in parallel with each other.
In both cases I then used the equivilant value for R and used it with the emf to find the terminal voltage. Both cases gave me voltages in the high 13's, but the answer is 14.1V can anyone start me off the right way?
Nevermind, I eventually got it to come out to the right answer
I can provide a response to this content by explaining the concept of terminal voltage and how it relates to circuits.
Terminal voltage is the potential difference between the terminals of a battery or any other source of electrical energy. In this case, we have a battery with an emf (electromotive force) of 15V. This means that the battery can provide a potential difference of 15V to the circuit. However, when the switch is closed, the internal resistance of the battery (0.5 ohms) will cause a drop in voltage, resulting in a lower terminal voltage.
To calculate the terminal voltage when the switch is closed, we can use the equation V terminal = E - Ir, where V terminal is the terminal voltage, E is the emf, I is the current flowing through the circuit, and r is the internal resistance. In this case, we have three resistors of equal value (5.5 ohms each) connected in parallel to the battery. This means that the total resistance of the circuit is 5.5/3 = 1.83 ohms.
To find the current flowing through the circuit, we can use Ohm's law, V=IR, where V is the voltage drop across the resistor (which is equal to the emf of the battery), I is the current, and R is the resistance. So, I = V/R = 15/1.83 = 8.2A.
Now, we can plug in these values in the equation for terminal voltage: V terminal = 15V - (8.2A * 0.5 ohms) = 14.1V. This is the correct answer.
When the switch is open, there is no current flowing through the circuit, so the voltage drop across the internal resistance is zero. Therefore, the terminal voltage will be equal to the emf of the battery, which is 15V.
In summary, the terminal voltage of a battery depends on the emf of the battery and the current flowing through the circuit, taking into account the internal resistance of the battery. When the switch is closed, the terminal voltage will be lower due to the voltage drop across the internal resistance. When the switch is open, the terminal voltage will be equal to the emf of the battery.
What is a circuit?
A circuit is a path through which electricity can flow. It is made up of various components, such as wires, resistors, and switches, that are connected in a closed loop.
What is voltage?
Voltage is the measure of the potential energy difference between two points in a circuit. It is often referred to as the "pressure" that drives the flow of electricity.
How is terminal voltage different from emf?
Terminal voltage is the voltage that can be measured at the terminals of a power source, such as a battery, when it is connected to a circuit. It is often lower than the electromotive force (emf), which is the maximum voltage that the power source can provide.
What factors affect terminal voltage?
The main factors that affect terminal voltage are the resistance of the circuit, the current flowing through the circuit, and the internal resistance of the power source. These can cause a voltage drop and affect the overall terminal voltage.
How can terminal voltage be calculated?
To calculate terminal voltage, you can use Ohm's Law, which states that voltage (V) is equal to current (I) multiplied by resistance (R). In other words, V = IR. You can also use Kirchhoff's Voltage Law, which states that the sum of the voltage drops in a closed loop circuit is equal to the sum of the voltage sources.
12K
